[petsc-dev] threadcomm memory leak
Barry Smith
bsmith at mcs.anl.gov
Tue Jul 17 13:17:56 CDT 2012
Why all this messy attribute check on Petsc_Counter_keyval ... stuff? Why not just ALWAYS call PetscCommDuplicate() and then check it for Petsc_ThreadComm_keyval and stick in the threadcomm if not there? That is, there is no reason to spread knowledge of Petsc_Counter_keyval into other places since other places can just use PetscCommDuplicate() to manage that.
Barry
+PetscErrorCode PetscThreadCommAttach(MPI_Comm comm,PetscThreadComm tcomm)
+ PetscErrorCode ierr;
+ MPI_Comm icomm;
+ PetscMPIInt flg,flg1,flg2;
+ void *ptr;
+ PetscCommCounter *counter;
+ PetscFunctionBegin;
+ ierr = MPI_Attr_get(comm,Petsc_Counter_keyval,&counter,&flg);CHKERRQ(ierr);
+ if(!flg) { /* Communicator not initialized yet */
+ ierr = PetscCommDuplicate(comm,&icomm,PETSC_NULL);CHKERRQ(ierr);
+ tcomm->refct++;
+ ierr = MPI_Attr_put(icomm,Petsc_ThreadComm_keyval,tcomm);CHKERRQ(ierr);
+ } else {
+ ierr = MPI_Attr_get(comm,Petsc_InnerComm_keyval,&ptr,&flg1);CHKERRQ(ierr);
+ if(flg1) {
+ ierr = PetscMemcpy(&ptr,&icomm,sizeof(MPI_Comm));CHKERRQ(ierr);
+ ierr = MPI_Attr_get(icomm,Petsc_ThreadComm_keyval,&ptr,&flg2);CHKERRQ(ierr);
+ if(!flg2) {
+ tcomm->refct++;
+ PetscFunctionReturn(0);
On Jul 17, 2012, at 3:14 AM, Shri wrote:
> Barry, Jed,
> Please see the attached patch based on Barry's suggestions. I tested this with MPI and MPIUNI and did not see any memory leaks. Let me know what you think.
> Thanks,
> Shri<threadcomm.patch>
> On Jul 16, 2012, at 11:00 PM, Barry Smith wrote:
>> Note that in general I would advocate in any code (especially PETSc code) NEVER blinding putting an attribute into a MPI_Comm, always check if the attribute is already there and only put it there if it is not already there.
>> Barry
>> On Jul 16, 2012, at 10:48 PM, Jed Brown wrote:
>>> On Mon, Jul 16, 2012 at 10:44 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> /* PETSC_COMM_SELF = PETSC_COMM_WORLD for MPIUNI */
>>> #if !defined(PETSC_HAVE_MPIUNI)
>>> ierr = PetscCommDuplicate(PETSC_COMM_WORLD,&icomm,PETSC_NULL);CHKERRQ(ierr);
>>> ierr = MPI_Attr_put(icomm,Petsc_ThreadComm_keyval,(void*)tcomm);CHKERRQ(ierr);
>>> tcomm->refct++; /* Share the threadcomm with PETSC_COMM_SELF */
>>> #endif
>>> ierr = PetscCommDuplicate(PETSC_COMM_SELF,&icomm,PETSC_NULL);CHKERRQ(ierr);
>>> I would not do it this way. Instead I would write a general routine that attached a threadcomm to a MPI_Comm; this routine would get the threadcomm_keyval and if it did NOT find it then would be put the attribute, otherwise it would know one was already there. Say it is called PetscThreadCommAttach(MPI_Comm, threadcomm); then in this routine you would just write
>>> PetscThreadCommAttach(PETSC_COMM_WORLD, tcomm);
>>> PetscThreadCommAttach(PETSC_COMM_SELF,tcomm); /* won't attr it again for MPIUni because it is already there */
>>> This looks good, but there is also a ref-counting check needed in PetscThreadCommDetach/Destroy because the thread pool (presumably) needs to be closed before PetscFinalize returns.
