[petsc-dev] threadcomm memory leak
Mon Jul 16 18:47:48 CDT 2012
On Mon, Jul 16, 2012 at 5:44 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   I totally agree it is a hack and should never be used, BUT as far as I
> was aware in no place in PETSc did we do that? If that is it should be
> fixed. But the fix is likely not forcing mpiuni to have two communicators
> it is just to do things right.
Do you not consider
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/169c19e9ea54to be a hack?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120716/7b5337f9/attachment.html>
