[petsc-dev] threadcomm memory leak
Mon Jul 16 11:11:39 CDT 2012
On Mon, 16 Jul 2012, Blaise Bourdin wrote:
> On Jul 16, 2012, at 10:11 AM, Jed Brown wrote:
> > On Mon, Jul 16, 2012 at 10:09 AM, Shri <abhyshr at mcs.anl.gov> wrote:
> > Yes, i think so too. If no one objects then i can do that.
> > Btw, MPI_COMM_SELF and MPI_COMM_WORLD are same in mpiuni/mpi.h
> > #define MPI_COMM_WORLD       1
> > #define MPI_COMM_SELF        MPI_COMM_WORLD
> >  while the fortran version declares these communicators as different. mpiuni/mpif.h
> >  integer MPI_COMM_WORLD
> >        parameter (MPI_COMM_WORLD = 1)
> >        integer MPI_COMM_SELF
> >        parameter (MPI_COMM_SELF = 2)
> > WAT? The Fortran version did something right?
> That's because it is tested by people who do stuff with it ;)
Actually for np=1 MPI_COMM_SELF==MPI_COMM_WORLD.
mpi.h was changed to reflect this  - but mpif.h was not.
Satish
balay at petsc:~/Petsc-historic/src/sys/src/mpiuni $ rcsdiff -r1.52 -r1.53 mpi.h
RCS file: RCS/mpi.h,v
retrieving revision 1.52
retrieving revision 1.53
diff -r1.52 -r1.53
1c1
< /* $Id: mpi.h,v 1.52 1997/07/28 21:41:02 balay Exp $ */
> /* $Id: mpi.h,v 1.53 1997/08/21 01:06:19 balay Exp $ */
22c22
< #define MPI_COMM_SELF        2
427c427
<                       (MPIUNI_TMP = (void *) (comm), \
>                       (*(newcomm) =  (comm), \
429d428
<                       MPIUNI_TMP = (void *) (newcomm), \
