[petsc-dev] threadcomm memory leak
Mon Jul 16 09:46:33 CDT 2012
On Mon, Jul 16, 2012 at 9:44 AM, Shri <abhyshr at mcs.anl.gov> wrote:
>   You need to do similar for your elemental grid to avoid memory leaks
> when using mpiuni.
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/169c19e9ea54
Isn't the right solution to fix MPIUNI so that they aren't literally the
same comm?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120716/4de40610/attachment.html>
