[petsc-dev] threadcomm memory leak
Sun Jul 15 17:37:20 CDT 2012
On Sun, Jul 15, 2012 at 5:26 PM, Shri <abhyshr at mcs.anl.gov> wrote:
> >   Why not just remove all the old pthread code now; it will make things
> clearer.
> Don't want to hurl people who are using/testing it into darkness.
It was always experimental and it's going to be removed anyway, so let's do
it sooner rather than later.
Some of that code could be used in the new implementations, but it was
pretty mechanical in the first place and I think copying it over is likely
to be just as error-prone as extracting from the current routines.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120715/81aae455/attachment.html>
