[petsc-dev] threadcomm memory leak
Sun Jul 15 16:57:08 CDT 2012
On Jul 15, 2012, at 4:48 PM, Shri wrote:
> On Jul 15, 2012, at 3:27 PM, Barry Smith wrote:
>> Shri,
>>   You need to test your code WITHOUT pthreads OR openmp configure.
> That is what i am doing, no openmp or pthreads.
>> You have the call to PetscThreadCommFinalize()  protected by PTHREADCLASSES
> There is no PetscThreadCommFinalize(). There is a 'PetscThreadsFinalize()' call in PetscFinalize() that is protected by PTHREADCLASSES. PetscThreadsFinalize() is for finalizing the previous pthread pool model that i had added on which vec_type pthread and mat_type seqaijpthread are based. It has nothing to do with threadcomm. Once i add new vector and matrix code using threadcomm , i'll remove the old pthread code and the pthread vector and matrix class.
   Why not just remove all the old pthread code now; it will make things clearer.
>> but not PetscThreadCommInitializePackage() projected!   Also why do you call PetscThreadCommPackageInitialize() at the beginning but PetscThreadCommFinalize() at the end and not PetscThreadCommFinalizePackage()?
> PetscThreadCommFinalizePackage is registerfinalized in PetscThreadCommInitializePackage()
> ierr = PetscRegisterFinalize(PetscThreadCommFinalizePackage);CHKERRQ(ierr);
   Sorry my mistake.
> So it is called on PetscRegisterFinalizeAll().
>>  BTW: If I #if def out the PetscThreadCommPackageInitialize() then nothing works (I have built without pthread classes and without openmp).  So there is some bad stuff going on.
> PetscThreadCommPackageInitialize() attaches the threadcomm attribute on the MPI communicator and there are several places where the threadcomm attribute is requested (sys/objects/subcomm.c, src/sys/tagm.c). Hence, the errors.
   Try a build with mpiuni. Maybe the memory leak is because that isn't handling stuff possible.   My build with memory leaks is with mpiuni.
   Thanks
   Barry
> Thanks,
> Shri
>>  Barry
>> On Jul 15, 2012, at 11:54 AM, Shri wrote:
>>> On Jul 14, 2012, at 7:55 PM, Satish Balay wrote:
>>>> I see this with 32bit linux build - but not 64bit linux build.
>>> I tried a fresh clone on my Mac and a linux cluster (both x86_64) but still did not get  any memory leaks. Perhaps this is a 32 bit build issue as Satish mentions. What configure options do i need to have a 32 bit build on x86_64? CC="gcc -m32" FC="gfortran -m32"?
>>> Thanks,
>>> Shri
>>>> also 32bit linux build gives errors with -fp_trap in ddot(). Haven't checked why.
>>>> Satish
>>>> On Sat, 14 Jul 2012, Barry Smith wrote:
>>>>> Many of them with make test
>>>>> Running test examples to verify correct installation
>>>>> Using PETSC_DIR=/Users/barrysmith/Src/petsc-dev and PETSC_ARCH=arch-float128-opt
>>>>> Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
>>>>> See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>> lid velocity = Qg, prandtl # = Qg, grashof # = Qg
>>>>> Number of SNES iterations = 2
>>>>> [0]Total space allocated 6880 bytes
>>>>> [ 0]16 bytes PetscThreadCommReductionCreate() line 260 in /Users/barrysmith/Src/petsc-dev/src/sys/threadcomm/interface/threadcommred.c
>>>>> [ 0]16 bytes PetscThreadCommReductionCreate() line 259 in /Users/barrysmith/Src/petsc-dev/src/sys/threadcomm/interface/threadcommred.c
>>>>> [ 0]48 bytes PetscThreadCommReductionCreate() line 258 in /Users/barrysmith/Src/petsc-dev/src/sys/threadcomm/interface/threadcommred.c
>>>>> [ 0]16 bytes PetscThreadCommInitialize() line 698 in /Users/barrysmith/Src/petsc-dev/src/sys/threadcomm/interface/threadcomm.c
>>>>> [ 0]176 bytes PetscThreadCommInitialize() line 694 in /Users/barrysmith/Src/petsc-dev/src/sys/threadcomm/interface/threadcomm.c
>>>>> [ 0]272 bytes PetscThreadCommInitialize() line 692 in /Users/barrysmith/Src/petsc-dev/src/sys/threadcomm/interface/threadcomm.c
>>>>> [ 0]16 bytes PetscThreadCommSetAffinities() line 331 in /Users/barrysmith/Src/petsc-dev/src/sys/threadcomm/interface/threadcomm.c
>>>>> [ 0]48 bytes PetscThreadCommCreate() line 122 in /Users/barrysmith/Src/petsc-dev/src/sys/threadcomm/interface/threadcomm.c
>>>>> [ 0]320 bytes PetscThreadCommCreate() line 118 in /Users/barrysmith/Src/petsc-dev/src/sys/threadcomm/interface/threadcomm.c
>>>>> Completed test examples
>>>>> barry-smiths-macbook-pro:petsc-dev barrysmith$
>>>>> On Jul 14, 2012, at 6:36 PM, Shri wrote:
>>>>>> Which example are you running? I don't see any memory leak for the examples i've tested (threadcomm examples sys/threadcomm/examples/tutorials/ and snes/examples/tutorials/ex19.c,ex5.c)
>>>>>> On Jul 14, 2012, at 4:22 PM, Barry Smith wrote:
>>>>>>> Please always test for memory leaks before pushing
>>>>>>> [0]  PetscThreadCommInitialize() line 685 in /Users/barrysmith/Src/petsc-dev/src/sys/threadcomm/interface/threadcomm.c
>>>>>>> [0]  PetscThreadCommInitializePackage() line 53 in /Users/barrysmith/Src/petsc-dev/src/sys/threadcomm/interface/dlregisthreadcomm.c
