[petsc-dev] how to use GPU, is my speed up sufficient?
Olga Tramontano tramontanoolga at yahoo.it
Thu Jul 12 10:42:10 CDT 2012
Hi all
I am very new to PETSc. I just learnt its class structure and I just understood that the interface Vec has been reimplemented with the class VecCUSP that is able to support GPU. My question is: if I have a simple code that allocates a vector and sets it with the database options, if I specify -vec_type seqcusp then this vector is allocated AND computed on the GPU?
Because I compared the execution time of the same algorithm with the database options -vec_type seq and -vec_type seqcusp: these two times are very close.
This is the code: I'm just trying to compute how long does it take to execute the function VecScale:
#include <petscvec.h>
#include <string.h>
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc,char **argv)
  Vec            x;
  PetscInt       n;
  PetscErrorCode ierr;
  PetscBool exists;
  PetscLogDouble  t1,t2;
  PetscInt a=10;
  ierr = PetscInitialize(&argc,&argv,(char*)0,help);CHKERRQ(ierr);
  ierr = PetscOptionsGetInt(PETSC_NULL,"-size",&n,&exists); CHKERRQ(ierr);
  ierr = VecCreate(PETSC_COMM_SELF,&x);CHKERRQ(ierr);
  ierr = VecSetSizes(x,PETSC_DECIDE,n);CHKERRQ(ierr);
  ierr = VecSetFromOptions(x);CHKERRQ(ierr);
  ierr = VecSetRandom(x, PETSC_NULL); CHKERRQ(ierr);
  PetscGetTime(&t1);
  ierr = VecScale(x,a); CHKERRQ(ierr);
  PetscGetTime(&t2);
  ierr = PetscPrintf(PETSC_COMM_WORLD, "%2.5f\n",(t2-t1));
  ierr = VecDestroy(&x);CHKERRQ(ierr);
  ierr = PetscFinalize();
  return 0;
I use a  vector of about 500000 numbers. With the database option -vec_type seqcusp , the method VecScale should call the method VecScale_SeqCUSP, right? Am I wrong? Should I do it expressly?
Anyway with the option -vec_type seq , the method VecScale takes 0.05681 seconds,
with the option -vec_type seqcusp,  the method VecScale takes 0.04242 seconds.
Is this speed up sufficient and realistic?
thanks
Olga
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120712/816bd0ae/attachment.html>
