[petsc-dev] [petsc-users] FFT Matrix Examples/Tests: Compiletime error
Hong Zhang hzhang at mcs.anl.gov
Wed Jul 11 12:01:57 CDT 2012
Thomas:
I removed src/mat/examples/tests/ex145.c and ex154.c from petsc-3.3 and
petsc-dev
because these tests are covered by other FFTW examples. This would reduce
our maintenance and confusion to users.
For complex precision, see ex143.c
Hong
On Wed, Jul 11, 2012 at 8:12 AM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Thomas:
>> Thx Hong. I tried the ex148, but I doesn't work as I have complex
>> petsc scalars. Instead I tried ex154, where I did the following
>> modification to be able to compile it
> ex148.c only works with real precision:
> #if defined(PETSC_USE_COMPLEX)
>   SETERRQ(PETSC_COMM_WORLD,PETSC_ERR_SUP, "This example requires real
> numbers");
> #endif
> As you see, these examples were written last summer,
> and have not been checked/tested with FFTW since then, therefore
> messy and buggy. I'll check what you reported below
> and get back to you soon.
> Thanks for reporting the problems,
> Hong
>>  hg diff
>> diff -r b800705fa966 src/mat/examples/tests/ex154.c
>> --- a/src/mat/examples/tests/ex154.c    Tue Jul 10 21:23:47 2012 -0500
>> +++ b/src/mat/examples/tests/ex154.c    Wed Jul 11 11:06:03 2012 +0200
>> @@ -46,7 +46,7 @@
>>    ierr = VecGetSize(input,&vsize);CHKERRQ(ierr);
>>    printf("The vector size of output from the main routine is
>> %d\n",vsize);
>> -  ierr = InputTransformFFT(A,input,x);CHKERRQ(ierr);
>> +  ierr = VecScatterPetscToFFTW(A,input,x);CHKERRQ(ierr);
>>  //  ierr = VecAssemblyBegin(x);CHKERRQ(ierr);
>>  //  ierr = VecAssemblyEnd(x);CHKERRQ(ierr);
>>  //  ierr = VecView(x,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>> @@ -54,7 +54,9 @@
>>    ierr = MatMult(A,x,y);CHKERRQ(ierr);
>>    ierr = MatMultTranspose(A,y,z);CHKERRQ(ierr);
>> -  ierr = OutputTransformFFT(A,z,output);CHKERRQ(ierr);
>> +  ierr = VecScatterFFTWToPetsc(A,z,output);CHKERRQ(ierr);
>> +  /* Check accuracy */
>>    fac = 1.0/(PetscReal)N;
>>    ierr = VecScale(output,fac);CHKERRQ(ierr);
>> Running this program with a single node (mpirun -n 1 ex154) works but
>> with multiple (mpirun -n 2 ex154) I get a segfault
>> http://pastie.tk/view.php?id=29C95711
>> ex143 with -use_FFTW_interface YES and-use_FFTW_interface NO  works
>> for both single and multiple nodes. ex145 only for more than one node
>> (as expected).
>> Regards
>> Thomas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120711/09321d68/attachment.html>
