[petsc-dev] [petsc-users] FFT Matrix Examples/Tests: Compiletime error
Hong Zhang hzhang at mcs.anl.gov
Tue Jul 10 17:30:49 CDT 2012
I fixed this problem in petsc-3.3 and petsc-dev.
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/3287ab3cb0ed
Hong
On Tue, Jul 10, 2012 at 1:03 PM, Sean Farley <sean at mcs.anl.gov> wrote:
> On Tue, Jul 10, 2012 at 12:50 PM, Thomas Hisch <t.hisch at gmail.com> wrote:
> > However, compilation of the ex148 example in src/mat/examples/tests/
> > still failes! Maybe I did something wrong. diff shows no differenece
> > between ex148.c from petsc-dev and petsc-3.3-p1. I tried to compile
> > ex148 by typing 'make ex148' in src/mat/examples/tests/  - is this the
> > correct way ?
> > Again, here is the error message:
> > mpicxx -o ex148.o -c -Wall -Wwrite-strings -Wno-strict-aliasing
> > -Wno-unknown-pragmas -O3 -fPIC
> > -I/home/thomas/local/src/petsc-dev/include
> > -I/home/thomas/local/src/petsc-dev/arch-linux2-cxx-release/include
> > -I/usr/lib/openmpi/include -I/usr/lib/openmpi/include/openmpi
> > -D__INSDIR__=src/mat/examples/tests/ ex148.c
> > ex148.c: In function ‘PetscInt main(PetscInt, char**)’:
> > ex148.c:45:37: error: ‘InputTransformFFT’ was not declared in this scope
> > ex148.c:54:39: error: ‘OutputTransformFFT’ was not declared in this scope
> > make: [ex148.o] Error 1 (ignored)
> > mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
> > -O3   -o ex148 ex148.o
> > -Wl,-rpath,/home/thomas/local/src/petsc-dev/arch-linux2-cxx-release/lib
> > -L/home/thomas/local/src/petsc-dev/arch-linux2-cxx-release/lib
> > -lpetsc -lX11
> > -lfftw3_mpi -lfftw3 -lpthread
> > -Wl,-rpath,/opt/intel/composer_xe_2011_sp1.11.339/mkl/lib/intel64
> > -L/opt/intel/composer_xe_2011_sp1.11.339/mkl/lib/intel64 -llapack
> > -lblas -Wl,-rpath,/usr/lib/openmpi/lib -L/usr/lib/openmpi/lib
> > -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/4.7
> > -L/usr/lib/gcc/x86_64-linux-gnu/4.7
> > -Wl,-rpath,/usr/lib/x86_64-linux-gnu -L/usr/lib/x86_64-linux-gnu
> > -Wl,-rpath,/lib/x86_64-linux-gnu -L/lib/x86_64-linux-gnu
> > -Wl,-rpath,/opt/intel/composer_xe_2011_sp1.11.339/compiler/lib/intel64
> > -L/opt/intel/composer_xe_2011_sp1.11.339/compiler/lib/intel64
> > -Wl,-rpath,/opt/intel/composer_xe_2011_sp1.10.319/compiler/lib/intel64
> > -L/opt/intel/composer_xe_2011_sp1.10.319/compiler/lib/intel64
> > -Wl,-rpath,/opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/intel64
> > -L/opt/intel/composer_xe_2011_sp1.10.319/ipp/lib/intel64
> > -Wl,-rpath,/opt/intel/composer_xe_2011_sp1.10.319/mkl/lib/intel64
> > -L/opt/intel/composer_xe_2011_sp1.10.319/mkl/lib/intel64
> -Wl,-rpath,/opt/intel/composer_xe_2011_sp1.10.319/tbb/lib/intel64/cc4.1.0_libc2.4_kernel2.6.16.21
> -L/opt/intel/composer_xe_2011_sp1.10.319/tbb/lib/intel64/cc4.1.0_libc2.4_kernel2.6.16.21
> > -lmpi_f90 -lmpi_f77 -lgfortran -lm -lgfortran -lm -lgfortran -lm -lm
> > -lquadmath -lm -lmpi_cxx -lstdc++ -ldl -lmpi -lopen-rte -lopen-pal
> > -lnsl -lutil -lgcc_s -lpthread -ldl
> > g++: error: ex148.o: No such file or directory
> > make: [ex148] Error 1 (ignored)
> > /bin/rm -f ex148.o
> Sorry for the bug, Thomas. It seems that a summer student last year caused
> this:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/dc6053cf3c78
> I would fix this but need to meet with my advisor soon. Could someone
> else look at this?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120710/dd69e4dd/attachment.html>
