[petsc-dev] Fwd: Problematic Merge of FieldSplit
Dmitry Karpeev karpeev at mcs.anl.gov
Sat Jul 7 03:23:48 CDT 2012
On Fri, Jul 6, 2012 at 9:56 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jul 6, 2012, at 9:35 PM, Matthew Knepley wrote:
> > On Fri, Jul 6, 2012 at 8:18 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    I don't understand this thread but I see nothing wrong with options
> like
> >     -fieldsplit_0_fieldsplit_0_fieldsplit_0....
> >    when using three nested levels of fieldsplit in the same way that
> three levels of block Jacobi (or ASM) gives -sub_sub_sub....
> >     The recursive nature of the prefixes should be completely natural
> and not require any special code ....
> >    Providing a prefix in the command line for other options seems
> terrible to me. Using the word inner also seems terrible; when you have
> _sub_sub that is clearly inner
> >     Could someone explain to me what prefixes are being  generated that
> are not the normal recursive process and why?
> > Sure, that is how it works in general. The point here is the distinction
> between A^{-1} in the (0,0) block and
> > A^{-1} embedded in S, which I will call A^{-1}_S. Right now we have
> >   a) A^{-1}_S and S have the same prefix
> > which Dmitry does not want (perfectly reasonable).
Before we had
> >   b) A^{-1} and A^{-1}_S had the same prefix
> > which I do not want since it makes things like SIMPLE hard. I wanted
> >   c) A^{-1}_S has prefix <prefix of S>_sub
> > but Dmitry said this was a hassle for normal setups and suggested that
> > we have some option that allows A^{-1} and A^{-1}_S to have different
> > prefixes.
>     Thanks, this makes things much clearer.
> 1) I don't like your prefix _sub (what the heck does _sub mean in this
> case) but I agree with you that having a different prefix there is good
> 2) I don't like Dmitry's solution. It introduces an entirely new paradigm
> that we don't have anywhere else in PETSc.
>     My thoughts ----------
>     For PCMG we have prefixes for the levels  mg_levels_%d_   if the user
> uses -mg_levels_ksp_type it applied to ALL the levels but if the user does
> -mg_levels_3_ksp_type it is applied only to the 3rd level. This is done by
> having the special treatment of _%d_ integers n the prefix that the options
> database can handle.  It would be nice if we could use this same basic
> paradigm to handle this new case that supports both what Dmitry and you
> want but not in a hacky ugly special case way.  For example (not so good)
> just use
>        -fieldsplit_0_ksp_type sets the same for both
>        -fieldsplit_0_0_ksp_type for the 0,0 block -fieldsplit_0_1_ksp_type
> for the solve inside the application of S.
>   this is not good because it uses 0 and 1 for the two solves (and 0 and 1
> have no particular meaning here) but the advantage is that it reuses
> current paradigms.
>    Going further we could have
>        -fieldsplit_0_outter_ksp_type for the 0,0 block and
> -fieldsplit_0_inner_ksp_type for the one inside the S
>    to implement this we would need to add support for %s in options
> prefixes. Maybe _<%s>_ so the options processing accepts a match with the
> string inside the <> or if that is not in the options database it accepts
> an option without the entire _<%s>_ This would require some small additions
> to PetscOptionsFind_private() like the
>   if (!*flg) {
>     PetscInt j,cnt = 0,locs[16],loce[16];
>     size_t   n;
>     ierr = PetscStrlen(tmp,&n);CHKERRQ(ierr);
>     /* determine the location and number of all _%d_ in the key */
>     for (i=0; i< (PetscInt)n; i++) {
>       if (tmp[i] == '_') {
>         for (j=i+1; j< (PetscInt)n; j++) {
>           if (tmp[j] >= '0' && tmp[j] <= '9') continue;
>           if (tmp[j] == '_' && j > i+1) { /* found a number */
>             locs[cnt]   = i+1;
>             loce[cnt++] = j+1;
>           break;
> What does everyone think?
I'm fine with this, except for the small detail that "outer" and "inner"
infixes might be obscure to the user.
I would advocate -fieldsplit_0_ksp_type by itself setting up both the inner
and outer A^{-1}, and -fieldsplit_0_schur_ksp_type
overriding the inner solver settings -- I think "Schur" is more descriptive
then "inner" and "outer".
Dmitry.
>    Barry
> >    Matt
> >    Barry
> > On Jul 6, 2012, at 8:39 AM, Matthew Knepley wrote:
> > > On Fri, Jul 6, 2012 at 7:28 AM, Dmitry Karpeev <karpeev at mcs.anl.gov>
> wrote:
> > > On Fri, Jul 6, 2012 at 8:17 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > On Fri, Jul 6, 2012 at 5:06 AM, Dmitry Karpeev <karpeev at mcs.anl.gov>
> wrote:
> > > Here's the line in question (also see the immediately preceding code):
> > > http://petsc.cs.iit.edu/petsc/petsc-dev/rev/0d4ccb990bb8#l1.127
> > > As long as we are fixing this, I would rather not repeat the prefix,
> since we will likely want to
> > > configure this differently than the block 0 solve. Is any thing wrong
> with
> > >   schurprefix+"_sub"
> > > If the inner and outer KSP prefixes are different, it will force one
> to repeat all of the configuration options for the inner and outer A00
> solvers, even when it is desirable to keep them identical.
> > > This becomes tedious, if the A00 solvers configuration is involved
> (e.g., a nested fieldsplit with separate options for the splits etc.).
> > > I would advocate making the inner solver use the same prefix as the
> outer solver by default, and allowing the user to specify
> > > a separate prefix for the inner solver, if it is to be configured
> differently.  For example:
> > > -fieldsplit_0_schur_prefix fieldsplit_0_inner -fieldsplit_0_ksp_type
> gmres -fieldsplit_0_inner_ksp_type preonly etc.
> > > As long as there is a way to do it.
> > >    Matt
> > > Dmitry.
> > >      Matt
> > > Dmitry.
> > > ---------- Forwarded message ----------
> > > From: Dmitry Karpeev <karpeev at mcs.anl.gov>
> > > Date: Fri, Jul 6, 2012 at 6:04 AM
> > > Subject: Re: [petsc-dev] Problematic Merge of FieldSplit
> > > To: For users of the development version of PETSc <
> petsc-dev at mcs.anl.gov>
> > > I have the following problem with the prefix choice for the
> MatSchurComplement KSP introduced in this changeset (
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/0d4ccb990bb8).
> > > I'm talking about the  "inner" KSP for A00, effecting inv(A00) in the
> definition S = A11 - A10 inv(A00) A01.
> > > We also have the "outer" inv(A00) KSP, which gets prefix "0".  I
> recently set the "inner" inv(A00) KSP
> > > prefix to "0", simply by inheriting it from the "outer" solver.  Now,
> it is completely reasonable
> > > to expect the inner and outer A00 KSPs to have different prefixes so
> that they can be configured differently.
> > > In fact, there was a recent petsc-users request related to this (
> http://lists.mcs.anl.gov/pipermail/petsc-users/2012-June/014005.html).
> > > However, currently the inner A00 KSP inherits the prefix from the A11
> KSP corresponding to the "1" field. With this prefix choice
> > > I end up configuring inv(A00) and inv(S) identically, which isn't what
> I want at all.
> > > I'm not sure what the right approach is, but the current one doesn't
> work for me.
> > > Note also that if A00 is treated with a recursive split, there may be
> numerous options for the A00 KSP.
> > > Do we want to repeat them for the inner and outer KSPs, if we want to
> configure them identically?
> > > It's automatic, if the two A00 KSPs share a prefix.  Again, this takes
> away some flexibility, so maybe it's not the best solution,
> > > but I think retaining a simple option for using identical
> configurations  is also highly desirable.
> > > Any ideas on how to handle this?
> > > Dmitry.
> > > On Tue, Jun 26, 2012 at 6:13 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > It turns out that 'hg rollback' during an 'hg rebase' does not do what
> I thought it did. I think
> > > everything is cleaned up with this push, but if you made FS changes in
> the past month, please
> > > check that it is doing what you want with prefixes, etc.
> > > Now, nested fieldsplits from the command line work, ala
> > > -ksp_type fgmres
> > > -pc_type fieldsplit -pc_fieldsplit_type additive
> > >   -pc_fieldsplit_0_fields 0,1
> > >     -fieldsplit_0_pc_type fieldsplit
> > >     -fieldsplit_0_pc_fieldsplit_type schur
> -fieldsplit_0_pc_fieldsplitschur_factorization_type full
> > >       -fieldsplit_0_fieldsplit_velocity_ksp_type preonly
> > >       -fieldsplit_0_fieldsplit_velocity_pc_type lu
> > >       -fieldsplit_0_fieldsplit_pressure_ksp_rtol 1e-10
> > >       -fieldsplit_0_fieldsplit_pressure_pc_type jacobi
> > >   -pc_fieldsplit_1_fields 2
> > >     -fieldsplit_temperature_ksp_type preonly
> > >     -fieldsplit_temperature_pc_type lu
> > > A split with only one field gets the field name, and otherwise a split
> number.
> > >     Matt
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > > -- Norbert Wiener
> experiments lead.
> > -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120707/14e25148/attachment.html>
