[petsc-dev] who did this?
Thu Jul 5 04:19:39 CDT 2012
This is years old, but in any case, fixed now:
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/30f9a34e118e
On Wed, Jul 4, 2012 at 10:17 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> /bin/sh: -c: line 0: syntax error near unexpected token `done'
> /bin/sh: -c: line 0: `/Users/barrysmith/Src/petsc-dev/arch-gnu/bin/mpiexec
> -n 1 ./ex37 -explicit_is 0 > ex37_1.tmp 2>&1;    /usr/bin/diff -w
> output/ex37_1.out ex37_1.tmp || echo
>  /Users/barrysmith/Src/petsc-dev/src/vec/vec/examples/tests "\nPossible
> problem with ex37_1, diffs above
> \n=========================================";   done; /bin/rm -f -f
> ex37_1.tmp'
> make[7]: [runex37] Error 2 (ignored)
> -n 1 ./ex37 -explicit_is 1 > ex37_1.tmp 2>&1;    /usr/bin/diff -w
> ex37_1.tmp'
> make[7]: [runex37_1] Error 2 (ignored)
> -n 2 ./ex37 -explicit_is 0 > ex37_2.tmp 2>&1;    /usr/bin/diff -w
> output/ex37_2.out ex37_2.tmp || echo
> problem with ex37_2, diffs above
> ex37_2.tmp'
> make[7]: [runex37_2] Error 2 (ignored)
> At least test your rule before pushing
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120705/53179dd4/attachment.html>
