[petsc-dev] preallocation checks
Sat Jan 28 16:59:36 CST 2012
On Jan 28, 2012, at 1:36 PM, Jed Brown wrote:
> On Sat, Jan 28, 2012 at 13:27, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Since MatSetUpPreallocated() was called inside MatSetValues() the macro MatPreallocated() was added to prevent unneeded functions calls in the inner kernel MatSetValues().
>   With modern PETSc we can get rid of MatPreallocated() everywhere and use MatSetUpPreallocation() directly everywhere then
> 1)  say we don't think that function call overhead matters where it is called now or
> This, but we have to remove it from the other functions that also should not be collective: MatGetRow, MatGetRowUpperTriangular, etc are obvious.
   Yup.
> What about MatGetOwnershipRange()? If the user had
> MatGetSizes(A,&m,NULL);
> if (m) {
>   MatGetOwnershipRange(A,&rstart,&rend);
>   for (i=rstart; i<rend; i++) { ... }
> this could deadlock if there are any empty procs. And MatGetBlockSize().
> 2) turn it into a static inline function.
> It can only be called from functions that are already collective.
   Make it simple. Always require calling MatXXXSetPreallocation() or MatSetUpPreallocation().  All these issues go out the window and user confusion about when it is needed goes out the window.
   Barry
