[petsc-dev] Subcomms
Mark F. Adams mark.adams at columbia.edu
Sat Jan 28 13:52:35 CST 2012
On Jan 28, 2012, at 1:48 PM, Barry Smith wrote:
> On Jan 28, 2012, at 12:42 PM, Barry Smith wrote:
>> On Jan 28, 2012, at 12:34 PM, Mark F. Adams wrote:
>>> On Jan 28, 2012, at 1:10 PM, Barry Smith wrote:
>>>> On Jan 28, 2012, at 10:59 AM, Matthew Knepley wrote:
>>>>> On Sat, Jan 28, 2012 at 8:00 AM, Mark F. Adams <mark.adams at columbia.edu> wrote:
>>>>> On Jan 27, 2012, at 8:22 PM, Barry Smith wrote:
>>>>>> On Jan 27, 2012, at 6:36 PM, Mark F. Adams wrote:
>>>>>>> On Jan 27, 2012, at 6:58 PM, Jed Brown wrote:
>>>>>>>> On Fri, Jan 27, 2012 at 17:48, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>>>> Is now the right time. Shouldn't we wait until MPI's replacement is working and do things with that model?
>>>>>>>> I'm laughing. Am I supposed to be?
>>>>>>>> I'm laughing too.
>>>>>>>> There isn't going to be a replacement for MPI until the smart people that understand parallel programming, performance, and libraries start working on something other than MPI. But most of those people are on the MPI Forum, trying to improve MPI. Now we need a good model for threads, and that might not be based on MPI, but it sure looks like the large-scale distributed-memory model will be MPI for the foreseeable future.
>>>>>>> I don't think its a matter of smart people not having worked on this, they have IMO, its just a hard problem.
>>>>>> I disagree; it is not necessarily hard, it is just that the non-MPI people are pretty fucking stupid.
>>>>> It is not hard, intellectually intriguing, fundable, and smart people won't do it.  What am I missing?
>>>>> I think Barry's point is that this is another case where, no matter how smart or motivated you are, if you start
>>>>> out with a bad design decision in the beginning, and refuse to change it for whatever reason, you will not
>>>>> succeed.
>>>> Matt's got it!  The slight difference is that I submit is that people who "start out with a bad design decision in the beginning, and refuse to change it for whatever reason" are fundamentally stupid even though they may be considered by most measures to be smart.  To me the "bad design decisions" are so blindly obviously wrong it is hard for me to label the people who "refuse to change it for whatever reason," anything but stupid, what other phrase should I use "smart in many ways but blindly stupid in this one regard?"
>>> Ok, first you two have changed the question (is this a Chicago thing?) -- why have "smart" people not done something that is "not hard" and an obviously important and even a hot ($) topic (for decades)?  You are implying some massive systemic market failure.
>>   Absolutely, it is a systemic market failure. It is a failure of the community due to largely sociological reasons.
>>> That said, I'm willing to go with the flow.  There are hundreds of parallel programming languages out there (http://en.wikipedia.org/wiki/List_of_concurrent_and_parallel_programming_languages).  You are implying that they are all done by rigid and narrow minded thinkers.  All of them.  Morons.  Really?
>>  This comes down to how to define "rigid and narrow minded thinkers", if you define that term by "starting out with a bad design decision in the beginning, and refuse to change it for whatever reason,"  then yes all those people are "rigid and narrow minded thinkers".  But be careful because many brilliant people are "rigid and narrow minded thinkers" it is just that where their brilliance has occurred did not overlap with their areas of "rigid and narrow mindedness". Look at the guy you discovered the DNA structure, Watson. If you look at certain aspects of his life he is clearly a complete and utter moron, yet he got a Nobel prize (for good reason) for one of the most fundamentally important breakthroughs in science. So yes, smart people can be morons.
>    I should also note that there is really no need or likely even possibility of a single parallel programming model that is appropriate for all scales and situations. So some of the languages designed you mentioned are designed for a particular regime and are fine for that particular regime so those models/languages are not stupid or hopeless.  The place where Matt's observed issue is  the high end HPC world.
OK, that is starting to sound plausible: a smallish mafia that is the HPC/programming languages community is closed to your friends.  Paranoid but plausible.
But I still think its a hard problem.  There are many constraints on a language and the inertia for science applications is immense.  The risk of failure is more than most application scientist can tolerate.  (eg, I recently heard of a code that decided to use python, which does not sound risky to me, but it takes 2 hours for python to load on 64K cores.  There are many failure modes in this business)
>    Barry
>>  Barry
>>>> Barry
>>>>> Matt
>>>>>> Barry
>>>>>>>> As for sources of parallel errors, yes, it's somewhat tricky, but as long as the model is to get a sub-object out of a bigger one (submatrix, coarse level, etc), I think we can manage it. At any particular time, the user should still be looking at essentially single-comm collections of objects, but not all processes will end up being called in every context.
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
