[petsc-dev] preallocation checks
Stefano Zampini stefano.zampini at gmail.com
Sat Jan 28 11:50:34 CST 2012
I was able to reproduce the error using
src/ksp/ksp/examples/tutorials/ex2.c using the patch attached.
Please see the error log obtained by executing with -n 10 -m 10 by command
line.
If you uncomment MatGetOwnershipRange, the code will work fine
2012/1/28 Jed Brown <jedbrown at mcs.anl.gov>
> On Sat, Jan 28, 2012 at 10:11, Stefano Zampini <stefano.zampini at gmail.com>wrote:
>> ierr = MatCreate(PETSC_COMM_SELF,&mat);CHKERRQ(ierr);
>> ierr = MatSetSize(mat,n,m,n,m);CHKERRQ(ierr);
>> ierr = MatSetType(mat,MATSEQDENSE);CHKERRQ(ierr);
>> -> Then a loop to set values
>> ierr = MatAssemblyBegin(mat);CHKERRQ(ierr);
>> ierr = MatAssemblyEnd(mat);CHKERRQ(ierr);
> I couldn't reproduce this with a modified
> MatSetUpPreallocation() should be sufficient in other cases.
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120128/e718b604/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120128/e718b604/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120128/e718b604/attachment-0001.obj>
