[petsc-dev] does petsc filter out zeros in MatSetValues?
Xuefei (Rebecca) Yuan xyuan at lbl.gov
Thu Jan 26 23:29:52 CST 2012
> On Thu, Jan 26, 2012 at 23:05, Xuefei Yuan <xyuan at lbl.gov> wrote:
> Moreover, When I use valgrind with --leak-check=yes --track-origins=yes, there are 441 errors from 219 contexts in PetscInitialize() before calling SNESSolve(). Is this normal for dev?
> Are you using Open MPI? MPICH2 should be clean or nearly so, provided the system libraries are okay.
no, I do not think so.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120126/fa4c50ba/attachment.html>
