[petsc-dev] does petsc filter out zeros in MatSetValues?
Thu Jan 26 20:26:23 CST 2012
On Thu, Jan 26, 2012 at 20:24, Mark F. Adams <mark.adams at columbia.edu>wrote:
> No, I can't imagine how, but there are several moving parts here.  I'm not
> sure about this issue.
> I did start getting an error on a malloc in MatSetValues - this is new
> right?
Yes, this is an experiment, we are setting MAT_NEW_NONZERO_ALLOCATION_ERR
by default if you preallocate. You can set the option to false if you are
intentionally not preallocating correctly.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120126/315a7677/attachment.html>
