[petsc-dev] bjacobi bugs ?
Hong Zhang hzhang at mcs.anl.gov
Thu Jan 26 16:00:51 CST 2012
On Jan 25, 2012, at 11:53 AM, Satish Balay wrote:
> > looks like this piece of code was last changed at:
> > http://petsc.cs.iit.edu/petsc/petsc-dev/rev/83c325962928
> > the new code added was 'PCSetUp_BJacobi_Multiproc' - different than
> 'PCSetUp_BJacobi_Multiblock'
>    So likely the multiproc code broke the singeblock/multiblock stuff
>   Hong can you check this please?
Fixed and pushed.
Hong
>   Barry
> > Satish
> > On Wed, 25 Jan 2012, Barry Smith wrote:
> >>   In PCSetUp_BJacobi() it has at the end
> >>     Setup code depends on the number of blocks
> >>  if (jac->n_local == 0) {
> >>    ierr = PCSetUp_BJacobi_Singleblock(pc,mat,pmat);CHKERRQ(ierr);
> >>  } else {
> >>    ierr = PCSetUp_BJacobi_Multiblock(pc,mat,pmat);CHKERRQ(ierr);
> >> does this make sense? No. In the normal case it is not using
> PCSetUp_BJacobi_Singleblock() at all! Something has gone wrong in the logic
> of the code when multiblock was added.
> >>    Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120126/a26ed7a1/attachment.html>
