[petsc-dev] bjacobi bugs ?
Wed Jan 25 11:53:21 CST 2012
looks like this piece of code was last changed at:
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/83c325962928
the new code added was 'PCSetUp_BJacobi_Multiproc' - different than 'PCSetUp_BJacobi_Multiblock'
Satish
On Wed, 25 Jan 2012, Barry Smith wrote:
>    In PCSetUp_BJacobi() it has at the end
>      Setup code depends on the number of blocks
>   if (jac->n_local == 0) {
>     ierr = PCSetUp_BJacobi_Singleblock(pc,mat,pmat);CHKERRQ(ierr);
>   } else {
>     ierr = PCSetUp_BJacobi_Multiblock(pc,mat,pmat);CHKERRQ(ierr);
> does this make sense? No. In the normal case it is not using PCSetUp_BJacobi_Singleblock() at all! Something has gone wrong in the logic of the code when multiblock was added.
>     Barry
