[petsc-dev] [petsc-maint #103192] Problem with petsc-dev "make test" failure
Dave Nystrom Dave.Nystrom at tachyonlogic.com
Sat Jan 21 15:37:38 CST 2012
See attached.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120121/9f8e992d/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120121/9f8e992d/attachment-0001.obj>
Barry Smith writes:
 > Damn thing is not printing the entire error message. Still some wrong use
 > of CHKERRCUSP() that should be CHKERRQ().
 > cd src/snes/examples/tutorials; make ex19; mpiexec -n 2 ./ex19 and send
 > all output to petsc-dev
 > Barry
 > On Jan 21, 2012, at 3:03 PM, Dave Nystrom wrote:
 > > In my latest attempt, petsc-dev seems to build fine but fails the "make test"
 > > case of running with 2 processes.  See attached files including my petsc-dev
 > > build script and its log file.
 > > Thanks,
 > > Dave
