[petsc-dev] error on preallocation business
Sat Jan 21 14:32:58 CST 2012
On Sat, Jan 21, 2012 at 11:50, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Jed,
>     It appears you changed all the MatXXXSetPreallocation() routines to
> set call  ierr =
> MatSetOption(B,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_TRUE);CHKERRQ(ierr);
> thus generating an error if preallocation is wrong.
>     The problem is that MatXXXSetPreallocation() is ALWAYS called (with
> default values if the user did not call it explicitly) by MatPreallocated()
> which calls MatPreallocationSetUp(). Hence you are ALWAYS setting error on
> new allocation.
>     My intention was that an error would only be generated if the user
> explicitly called MatXXXSetPreallocation() so
>   1) Was my intention wrong and should we always default to erroring on
> wrong preallocation even if the user did not preallocate or   (if so we
> need lots of fixes because much code is broken in nightly tests)
No, I think your idea was correct.
>   2) is there anyway to change it so it only errors out when the user did
> explicitly preallocate?
This patch is not pretty, but it seems to do the job.
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/e675ef955f92
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120121/46fa82e9/attachment.html>
