[petsc-dev] VecScatterBegin_1 with zero sized vectors and PETSC_HAVE_CUSP
Fri Jan 20 17:01:52 CST 2012
On Fri, 20 Jan 2012, Stefano Zampini wrote:
> Thank you, I'll let you know if it crashes again. Anyways, the problem is
> that xin->map->n (vpscat.h actual line 58) is zero for some of my vectors,
> and thus it will enter the if block even if I don't need to do anything
> with CUSP. Is it really important the first logic of the OR?
> Recompile will take a while since my petsc_arch on gpu cluster is not able
> to use cmake to build ( I saw missing files in CMakeLists.txt for CUSP and
> GPU related stuffs). Is it a known issue? Is there a way to simply
> recompile the changed code only?
Assuming includes have not changed - you can just do:
[for each location where files have changed - say for eg: src/ksp/ksp/interface ]
cd src/ksp/ksp/interface
make
or to get to every changed file automatically
cd $PETSC_DIR
make ACTION=lib tree
Satish
