[petsc-dev] VecScatterBegin_1 with zero sized vectors and PETSC_HAVE_CUSP
Fri Jan 20 14:27:25 CST 2012
   I do not understand the error traceback. It should NOT look like this. Is that really the exact output from a single failed run? There snould not be multiple messages of ----Error Message ---- etc. It shoul immediately after the first listing of Configure options show the complete stack where the problem happened instead it printed an initial error message again and then again and then finally a stack. This is not suppose to be possible. Are you running with multiple threads AND gpus? That won't work.
   Anyways I cannot find anywhere a list of Cusp error messages that include the numbers 46 and 76; why are not the except messages strings ???
   Barry
[17]PETSC ERROR: VecCUSPAllocateCheck() line 77 in src/vec/vec/impls/seq/seqcusp//work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/include/../src/vec/vec/impls/seq/seqcusp/cuspvecimpl.h
[17]PETSC ERROR: --------------------- Error Message ------------------------------------
[17]PETSC ERROR: Error in external library!
[17]PETSC ERROR: CUSP error 46!
[17]PETSC ERROR: ------------------------------------------------------------------------
[17]PETSC ERROR: Petsc Development HG revision:   HG Date:
[17]PETSC ERROR: See docs/changes/index.html for recent updates.
[17]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[17]PETSC ERROR: See docs/index.html for manual pages.
[17]PETSC ERROR: ./bidomonotest on a gnu-4.4.3 named ella011 by zampini Fri Jan 20 19:01:30 2012
[17]PETSC ERROR: Libraries linked from /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/gnu-4.4.3-debug-double-louis/lib
[17]PETSC ERROR: Configure run at Fri Jan 20 15:29:21 2012
[17]PETSC ERROR: Configure options --CUDAFLAGS=-m64 --with-cuda-dir=/caspur/local/apps/cuda/4.0 --with-cuda-arch=sm_20 --with-cusp-dir=/caspur/shared/gpu-cluster/devel/cusp/0.2/.. --with-thrust-dir=/caspur/local/apps/cuda/4.0/include --with-boost-dir=/caspur/shared/sw/devel/boost/1.44.0/intel/11.1.064 --with-pcbddc=1 --with-make-np=12 --with-debugging=1 --with-errorchecking=1 --with-log=1 --with-info=1 --with-cmake=/work/adz/zampini/cmake/2.8.7/bin/cmake --with-gnu-compilers=1 --with-pthread=1 --with-pthreadclasses=1 --with-precision=double --with-mpi-dir=/caspur/shared/sw/devel/openmpi/1.4.1/gnu/4.4.3 PETSC_DIR=/work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev PETSC_ARCH=gnu-4.4.3-debug-double-louis --with-shared-libraries=1 --with-c++-support=1 --with-large-file-io=1 --download-hypre=/work/adz/zampini/PetscPlusExternalPackages/hypre-2.7.0b.tar.gz --download-umfpack=/work/adz/zampini/PetscPlusExternalPackages/UMFPACK-5.5.1.tar.gz --download-ml=/work/adz/zampini/PetscPlusExternalPackages/ml-6.2.tar.gz --download-spai=/work/adz/zampini/PetscPlusExternalPackages/spai_3.0.tar.gz --download-metis=1 --download-parmetis=1 --download-chaco=1 --download-scotch=1 --download-party=1 --with-blas-lapack-include=/caspur/shared/sw/devel/acml/4.4.0/gfortran64/include/acml.h --with-blas-lapack-lib=/caspur/shared/sw/devel/acml/4.4.0/gfortran64/lib/libacml.a
[17]PETSC ERROR: VecCUSPCopyFromGPUSome() line 228 in src/vec/vec/impls/seq/seqcusp/veccusp.cu
[17]PETSC ERROR: CUSP error 76!
[17]PETSC ERROR: VecCUSPCopyFromGPUSome_Public() line 263 in src/vec/vec/impls/seq/seqcusp/veccusp.cu
[17]PETSC ERROR: VecScatterBegin_1() line 57 in src/vec/vec/utils//work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/include/../src/vec/vec/utils/vpscat.h
[17]PETSC ERROR: VecScatterBegin() line 1574 in src/vec/vec/utils/vscat.c
[17]PETSC ERROR: PCISSetUp() line 46 in src/ksp/pc/impls/is/pcis.c
[17]PETSC ERROR: PCSetUp_BDDC() line 230 in src/ksp/pc/impls/bddc/bddc.c
[17]PETSC ERROR: PCSetUp() line 832 in src/ksp/pc/interface/precon.c
[17]PETSC ERROR: KSPSetUp() line 261 in src/ksp/ksp/interface/itfunc.c
[17]PETSC ERROR: PCBDDCSetupCoarseEnvironment() line 2081 in src/ksp/pc/impls/bddc/bddc.c
[17]PETSC ERROR: PCBDDCCoarseSetUp() line 1341 in src/ksp/pc/impls/bddc/bddc.c
[17]PETSC ERROR: PCSetUp_BDDC() line 255 in src/ksp/pc/impls/bddc/bddc.c
On Jan 20, 2012, at 12:20 PM, Stefano Zampini wrote:
> Hi recently installed petsc-dev on a GPU cluster. I got an error in external library CUSP when calling PCISSetup: more precisely, doing VecScatterBegin on SEQ (not SEQCUSP!) vectors (please see the traceback attached). I'm developing the BDDC preconditioner code inside PETSc and this error occurred when doing multilevel: in such case some procs (like proc 17 in the case attached) has local  dimension (relevant to PCIS) equal to zero.
> Thus, I think the real problem stays on line 41 of src/vec/vec/utils/vpscat.h. If you tell me the reason why you used the first condition on the if clause I can patch the problem.
> Regards,
> Stefano
> <traceback>
