[petsc-dev] preallocation checks
Fri Jan 20 11:06:29 CST 2012
On Fri, Jan 20, 2012 at 11:03, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Not for seqaij you don't.   Come on, it is understandable we do a crummy
> job for a hard case but we should at least do a good job for an easy case.
MatConvert_X_SeqAIJ() would basically only be used to convert MatDense
because there is special case code for the other cases.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120120/5ccf0f27/attachment.html>
