[petsc-dev] -pc_type gamg for vector PDE
Fri Jan 20 06:47:25 CST 2012
On Fri, Jan 20, 2012 at 05:37, Alexander Grayver <agrayver at gfz-potsdam.de>wrote:
> Well in my case it is the other way around. I solve this equation for low
> \omega and possibly very low \sigma. The curl-curl term dominates always.
Yes, this is the hard regime.
> A few things to try:
>  1) '-pc_gamg_type sa' will provide what should be a better solver for
> SPD problems.
> Unfortunately, the convergence with this option is worse for several
> operators I've tried.
> Would it help to specify coordinates vertices?
SA does not use coordinates except to add rigid body modes to the near-null
space, but that near-null space is different and much smaller than your
near-null space.
> When configuring with hypre I get "Cannot use hypre with complex numbers
> it is not coded for this capability".
> I can reformulate my problem in terms of real matrix:
> If C = A + iB
> Cx=b  ==  [A -B; B A] [xr; xi] = [br; bi]
> But I'm not sure that making spectra two times larger would not influence
> my condition number?
It's probably not so bad for conditioning, but the methods on BoomerAMG are
not intended for Maxwell. Hypre's user's manual (and ML's) have sections on
solving Maxwell with their custom interfaces, you would have to read those
sections and call them directly (or add that functionality to the PETSc
interface; if you want to do this, we can advise and assist).
>  3) You say 'staggard' but I just see E here.  Do you have E on faces?  I
> forget how staggering works here.  If E is cell centered then you have a
> system of 3x3 blocks (with the right ordering) and GAMG might benefit from
> setting the block size to tell it this:
>  MatSetBlockSize(mat,3);
> I have fields on the edges, but I can formulate another staggering scheme
> where fields are on the faces. Would it help?
Not immediately. I'm not very familiar with the problem, but my
understanding is that the edge discretization is probably the one you want
anyway.
> My matrix is 3x3 block. For instance, if I have 100^3 grid, then matrix is
> 3*10^6 and each block is of 10^6 size.
> Which block size should I pass to MatSetBlockSize? 10^6 or 3? Because from
> its description it is not obvious.
This "block size" stuff is for "point blocks" where you have several dofs
collocated at points (or modes of a modal basis). You don't have that
structure because different variables are at different points, so you can't
readily interlace your three macro-blocks to make 3x3 point-blocks.
>  And Jed's answer addresses your 2nd question about null-space.  These
> solvers will degrade as \omega\mu\sigma gets smaller.
> I do observe this for low \omega and low \sigma (e.g. in the air). I was
> thinking how could one project out this null-space.
> Hitpmair, as Jed pointed, gives some clues. However it requires some
> efforts to implement and wanted first to try petsc built in stuff.
If you can afford it, I suggest using a direct solver like MUMPS. Depending
on your geometry, 10^6 dofs might be manageable (depending on how quickly
you need to solve these problems).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120120/371573c1/attachment.html>
