[petsc-dev] boomerAmg scalability
Ravi Kannan rxk at cfdrc.com
Mon Jan 9 13:54:47 CST 2012
Hi Mark,
Thanks for your efforts.
Do I need to do the install from scratch once again? Or some particular
files (check out gamg.c for instance)?
Ravi.
From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov]
On Behalf Of Mark F. Adams
Sent: Friday, January 06, 2012 10:30 AM
To: For users of the development version of PETSc
Subject: Re: [petsc-dev] boomerAmg scalability
I think I found the problem.  You will need to use petsc-dev to get the fix.
On Jan 6, 2012, at 8:55 AM, Mark F. Adams wrote:
Ravi, I forgot but you can just use -ksp_view_binary to output the matrix
data (two files).  You could run it with two procs and a Jacobi solver to
get it past the solve, where it writes the matrix (I believe).
On Jan 5, 2012, at 6:19 PM, Ravi Kannan wrote:
Just send in another email with the attachment.
On Behalf Of Jed Brown
Sent: Thursday, January 05, 2012 5:15 PM
On Thu, Jan 5, 2012 at 17:12, Ravi Kannan <rxk at cfdrc.com> wrote:
I have attached the verbose+info outputs for both the serial and the
parallel (2 partitions). NOTE: the serial output at some location says
PC=Jacobi! Is it implicitly converting the PC to a Jacobi?
Looks like you forgot the attachment.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120109/f64fa9fd/attachment.html>
