[petsc-dev] [petsc-maint #101028] Re: BDDC code
Stefano Zampini stefano.zampini at gmail.com
Mon Jan 9 09:15:07 CST 2012
2012/1/9 Jed Brown <jedbrown at mcs.anl.gov>
> Cc'ing petsc-dev to get other opinions.
Great.
> On Mon, Jan 9, 2012 at 06:56, Stefano Zampini <stefano.zampini at gmail.com>wrote:
>> Because of the way I built the code, different coarse problem types set
>> communicators and operators in a different way. Specifically,
>> - MULTILEVEL_BDDC: mat_type=MATIS, coarse_comm=comm of parent,
>> coarse_pc=PCBDDC.
>> - PARALLEL_BDDC: mat_type=MATMPIAIJ, coarse_comm=comm of parent,
>> coarse_pc=PCREDUNDANT.
> The only distinction here is the matrix type.
>> - SEQUENTIAL_BDDC (only rank 0 creates it): mat_type=MATSEQAIJ,
>> coarse_comm=PETSC_COMM_SELF, coarse_pc=PCLU.
> This should be handled through a mechanism like PCREDUNDANT so that the
> caller does not need to know. This "reduce to subcommunicator, broadcast
> the result" would be simple to add to PCREDUNDANT.
>> - REPLICATED_BDDC (all ranks creates the same sequential ksp):
>> mat_type=MATSEQAIJ, coarse_comm=PETSC_COMM_SELF, coarse_pc=PCLU.
> What does this have over using PCREDUNDANT as in case 2?
>>>>  indeed a possible user code
>>>> PCBDDCGetCoarseKSP(pcbddc,&coarse_ksp)
>>>> KSPGetPC(coarse_ksp,&coarse_pc)
>>>> PCSetType(coarse_pc,PCBDDC) (or something else)
>>>> PCSetup(pcbddc)
>>>> breaks at the second line since pcbddc->coarse_ksp doesn't exist before
>>>> calling PCSetup.
>>> You can make PCBDDCGetCoarseKSP() return a KSP that has not had its type
>>> set yet.
>> By creating the KSP object internally to the function call? In this case
>> the problem remains since the user should need to know a priori the type of
>> communicator associated with the KSP. Can we change the communicator after
>> we created the KSP object?
> No, but I think that the coarse communicator should probably always be the
> same as for the whole problem, and then use PCREDUNDANT or similar if we
> want to reduce to a subcomm.
Except for MULTILEVEL_BDDC, all other approaches solve exactly the coarse
problem thus there are no differences in theoretical results. In practice,
they are there for performances optimizations. REPLICATED_BDDC is performed
directly using allgatherv operations and it is an heritage from my previous
codes. I can drop it. If you can manage the SEQUENTIAL_BDDC case directly
in PCREDUNDANT, then we will be half-way. Enums on coarse communications
type will be eliminated too as communications can be all made using
VecScatters.
> But this brings up an issue that also appears in GAMG, how to expose user
> access to coarse KSPs even though they are created on adaptively sized
> subcomms. If we configure strictly through the options database, then we
> are okay, but what if we have to pass any information directly to the KSP?
> We can set operators and call PCSetUp(), then pull out levels, but what
> should be returned on ranks that are not participating?
Coarse KSP in my multilevel BDDC implementation is created on the same comm
of parent; ranks not partecipating in coarse comm will create all objects
needed my the levels even if they have a local dimension equal to zero.
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120109/9ca2371e/attachment.html>
