[petsc-dev] GMRES with one processor crashes
Mon Jan 9 08:00:14 CST 2012
On Mon, Jan 9, 2012 at 7:15 AM, Alexander Grayver
<agrayver at gfz-potsdam.de>wrote:
> And with petsc-3.2-p5 it works fine. Even though BLAS library is the same.
Okay, we should narrow this down with ex10. It may be connected with the
specific matrix.
1) Can you send us the matrix so we can run under valgrind here?
2) Can you send the valgrind log from ex10?
Sorry about the workload, but I do not know of a better way to debug these
kinds fo things.
    Matt
On 09.01.2012 14:09, Alexander Grayver wrote:
>> On 09.01.2012 13:26, Matthew Knepley wrote:
>>> Note that KSP ex10 does exactly this. Does it crash? This could be a
>>> BLAS incompatibility of some sort.
>> Yes, it does crash with the same error. I don't understand why does it
>> happen only with one process?
>> I use MKL BLAS library.
>>>   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120109/32bdf878/attachment.html>
