[petsc-dev] [petsc-maint #101466] Building external petsc packages without internet access
Fri Jan 6 21:04:33 CST 2012
  Satish,
   Barry
On Jan 6, 2012, at 3:05 PM, Satish Balay wrote:
> On Thu, 5 Jan 2012, Barry Smith wrote:
>> On Jan 5, 2012, at 7:30 PM, Satish Balay wrote:
>>> On Thu, 5 Jan 2012, Nystrom, William D wrote:
>>> The undeleted _d_sowing.tar.gz is a new thing in petsc. Its more like
>>> 'when this relavent code was changed we forgot to delete this
>>> temporaty file'. If you retained the acutal package source dirs [and
>>> not just the _d_foo.tar.gz] - then taring/untaring externalpackages
>>> would have worked.
>>    What the fuck are these files doing there?
>> barry-smiths-macbook-pro:petsc-dev barrysmith$ ls externalpackages/
>> MUMPS_4.10.0            _d_SuperLU.tar.gz       blacs-dev               metis-5.0.2             qblaslapack
>> Prometheus-1.8.9        _d_SuperLU_DIST.tar.gz  c2html-0.9.4            ml-6.2                  scotch_5.1.11_esmumps
>> Prometheus-1.8.9.tar.gz _d_f2cblaslapack.tar.gz f2cblaslapack-3.1.1.q   mpich2-1.4.1p1          sowing-1.1.16c
>> SCALAPACK-1.7           _d_fftw.tar.gz          fftw-3.3.1-beta1        numdiff-5.2.1           txpetscgpu-0.0.2
>> SuperLU_4.3             _d_metis.tar.gz         help                    openmpi-1.4.3           txpetscgpu-0.0.2.tar.gz
>> SuperLU_DIST_3.0-p1     _d_parmetis.tar.gz      hypre-2.7.0b            parmetis-4.0.2          yaml-0.1.4
>> _d_MUMPS.tar.gz         _d_sowing.tar.gz        junk                    pastix_release_3184
>>  Who added this moronic feature. Please fix it. After I finish crapping I flush the toilet. You don't?
> Looks like this happened when some of the shell code [for handling
> .gz/bz2 files] was replaced by python code. I've reorganized this code
> a bit more and fixed the temporary file deletion issue.
> Satish
