[petsc-dev] Is gamg in petsc 3.2?
Fri Jan 6 09:19:55 CST 2012
On Fri, Jan 6, 2012 at 09:05, Blaise Bourdin <bourdin at lsu.edu> wrote:
> Has gamg made its way into 3.2? If so, is there a magic trick to use it?
$ head -3 ~/petsc-3.2/src/ksp/pc/impls/gamg/makefile
#requirespackage  'PETSC_HAVE_TRIANGLE'
#requiresprecision double
#requiresscalar    real
These restrictions are gone in petsc-dev.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120106/2856d25f/attachment.html>
