[petsc-dev] SNES, Coloring, DM, and TS
Dmitry Karpeev karpeev at mcs.anl.gov
Tue Feb 28 14:16:24 CST 2012
On Tue, Feb 28, 2012 at 2:06 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Feb 28, 2012 at 13:52, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
>> I don't understand the need for multiple function evaluation routines and
>> their explicit naming.
>> I think the situation here is completely analogous to the situation with
>> matrices: I thought we agreed that each DM would be capable of generating a
>> single matrix, the "Jacobian", rather than multiple matrices like J and
>> J_pre, and that the different necessary matrices (again, e.g., J and J_pre)
>> would instead be produced by their respective DMs -- the KSP DM and the PC
>> DM, so to speak.  These subDMs would be pulled out of the SNES DM and
>> passed to the corresponding KSP and PC objects.  Thus, a DM encapsulates a
>> single "problem", and if we want to get a different problem -- the "exact"
>> linearization of the original, for example -- we extract the KSP DM;
>>  likewise, PC DM is an approximate linearization, and so on.
>> I don't think TS is any different -- we can have the TSI DM (maybe under
>> a better name), which could have DMFormFunction encapsulating the IFunction
>> (and, incidentally, a linearization encapsulating the mass matrix), etc.
> I'm concerned that this becomes insanity. A single TS might need
> RHSFunction, IFunction, and IJacobian. They might also partition terms
> differently for the functions and the Jacobian. Having different DMs seems
> awfully confusing.
> In short -- I'm for each DM having one function (DMFormFunction or,
>> better, DMFormResidual) and one matrix (DMFormJacobian) -- *a*
>> linearization of the residual.  All other functions and matrices are
>> obtained from the corresponding subDMs.
> The interface is actually different for these (compare TSIFunction, a
> transient residual, to SNESFunction)
Okay.  I would still refrain from calling these things by the class of the
object consuming them.  DMFormFunction() and DMFormIFunction() seem fine,
since these have a meaning independent of TS (although the DM has to then
encode a transient problem).  But I don't like DMGetSNESFunction() any more
than I like DMGetKSPJacobian() and DMGetPCJacobian().
By the way, should we start using Residual instead of Function?
Dmitry.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120228/702f2b62/attachment.html>
