[petsc-dev] Regarding an error
Tue Feb 28 06:26:08 CST 2012
I have pushed fixes for these issues, though I can't test them locally. Can
you check that it works now?
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/fd97cbc27dcc
On Tue, Feb 28, 2012 at 04:27, Chen S <chensp2602 at gmail.com> wrote:
> Hi ,
> I'm building petsc using cygwin (on a windows machine), and I got the
> following errors while running "make all",
> (this is the latest build, i've updated on Feb 28th. ):
> C:\cygwin\home\PETSC-~4\src\mat\coarsen\impls\mis\mis.c(352) : error
> C2016: C requires that a struct or union has at least one member
> C:\cygwin\home\PETSC-~4\src\mat\coarsen\impls\hem\hem.c(322) : error
> C:\cygwin\home\PETSC-~4\src\snes\impls\ms\ms.c(421) : error C2143: syntax
> error : missing ';' before 'type'
> C:\cygwin\home\PETSC-~4\src\snes\impls\ms\ms.c(424) : error C2065: 'ierr'
> : undeclared identifier
> C:\cygwin\home\PETSC-~4\src\snes\impls\ms\ms.c(432) : error C2065: 'ierr'
> C:\cygwin\home\PETSC-~4\src\snes\impls\ms\ms.c(434) : error C2065: 'ierr'
> C:\cygwin\home\PETSC-~4\src\snes\impls\ms\ms.c(436) : error C2065: 'ierr'
> C:\cygwin\home\PETSC-~4\src\snes\impls\ms\ms.c(437) : error C2065: 'ierr'
> C:\cygwin\home\PETSC-~4\src\snes\impls\ms\ms.c(438) : error C2065: 'ierr'
> C:\cygwin\home\PETSC-~4\src\snes\impls\ms\ms.c(439) : error C2065: 'ierr'
> C:\cygwin\home\PETSC-~4\src\snes\impls\ms\ms.c(440) : error C2065: 'ierr'
> C:\cygwin\home\PETSC-~4\src\snes\impls\ms\ms.c(442) : error C2065: 'ierr'
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(516) : error C2143:
> syntax error : missing ';' before 'type'
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(519) : error C2065:
> 'selected' : undeclared identifier
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(519) : warning C4047:
> 'function' : 'IS *' differs in levels of indirection from 'int *'
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(519) : warning C4024:
> 'function through pointer' : different types for formal and actual
> parameter 3
> 'llist' : undeclared identifier
> parameter 4
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(520) : error C2065:
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(520) : warning C4047:
> 'function' : 'IS' differs in levels of indirection from 'int'
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(520) : warning C4024:
> parameter 4
> parameter 5
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(538) : error C2065:
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(538) : warning C4047:
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(538) : warning C4024:
> 'ISDestroy' : different types for formal and actual parameter 1
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(539) : error C2065:
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(539) : warning C4047:
> C:\cygwin\home\PETSC-~4\src\ksp\pc\impls\gamg\gamg.c(539) : warning C4024:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120228/8733b435/attachment.html>
