[petsc-dev] petsc-dev on bitbucket
Stefano Zampini stefano.zampini at gmail.com
Mon Feb 27 15:34:57 CST 2012
I need to push some changes to bddc code. Here is my bitbucket name:
stefano_zampini
Stefano
2012/2/8 Sean Farley <sean at mcs.anl.gov>
> "Yoo, i've switched petsc-dev over to bitbucket since petsc.cs.itt.edu is
> down pull/push from https://bitbucket.org/petsc/petsc-dev
>     Sean" - Barry impersonating me
> Since petsc.cs is down, I don't have everyone's public SSH key. For now,
> if you need push access, just sign up for a free bitbucket account (can
> also use OpenID) and reply to this email with your bitbucket username.
> Barry, Matt, Jed, and Peter have write access already. Hong (hzhang),
> Dmitry (karpeev), and Lois (curfman) should have write access as long as
> the username in the parenthesis is your correct bitbucket name.
> Also, BuildSystem is here:
> https://bitbucket.org/petsc/buildsystem
> where the same people as above have write access.
> P.S. - To change your current default push url in mercurial, just edit
> $PETSC_DIR/.hg/hgrc
> [paths]
> default = https://bitbucket.org/petsc/petsc-dev
> or if you uploaded your public SSH key to bitbucket already
> [paths]
> default = ssh://hg@bitbucket.org/petsc/petsc-dev
> More info here:
> http://confluence.atlassian.com/display/BITBUCKET/Using+the+SSH+protocol+with+bitbucket
> P.P.S - While we're at it, here is a nice shortcut in mercurial. Place
> this in your ~/.hgrc
> [extensions]
> schemes =
> [schemes]
> petsc = ssh://hg@bitbucket.org/petsc
> You can now clone like so: `hg clone petsc://petsc-dev` or `hg clone
> petsc://buildsystem`
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120227/a25cd016/attachment.html>
