[petsc-dev] SNES, Coloring, DM, and TS
Mon Feb 27 11:21:02 CST 2012
On Mon, Feb 27, 2012 at 11:16 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Mon, Feb 27, 2012 at 11:00, Matthew Knepley <knepley at gmail.com> wrote:
>> I don't see why this is a dependency loop.
> 1. The callback interface is duplicated.
> 2. DM callbacks should provide a way for the called code to get access to
> the TS or DM so that users aren't prevented from doing hacky things.
Having DM hold the callbacks is a problem. But don't we have them in the
context arg?
>>> As a related matter, I'm stuck with a reference counting loop where I
>>> want to attach special Vecs to a DM. I can wrap them in a PetscContainer to
>>> circumvent the code that checks for reference cycles, but that makes
>>> freeing them delicate. We could make a named cache similar to DM work
>>> vectors, but where restored Vecs are not available for reuse.
>> I know that rationale for having Vecs know about a DM (output), which I
>> don't like. What is the rationale for having DMs know about a certain Vec?
> A TS wants to solve a nonlinear problem using FAS, so it needs to
> implement a callback on levels. So it coarsens the grid, but it also needs
> to coarsen the affine vectors so that it can define the finite-step problem
> on coarse levels.
> Same issue for lots of cases where a user needs to save grid setup,
> coefficient fields, etc on levels so that it is available in a callback.
> It's natural to compose those vectors with the DM, but that creates a
> reference loop.
Aren't they just passed in? Or do you mean auxiliary vectors?
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120227/31db95ef/attachment.html>
