[petsc-dev] the complex dot business
Alexander Grayver agrayver at gfz-potsdam.de
Mon Feb 27 11:16:01 CST 2012
On 27.02.2012 18:01, Matthew Knepley wrote:
> On Mon, Feb 27, 2012 at 10:55 AM, Barry Smith <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
>       I'm afraid the sudden appearance of the blas dot for complex
>     numbers problem is my fault.
>       Traditionally since 199x we never used the complex dot product
>     from blas because of the return complex type problem. VecDot_Seq()
>     used #ifdef for complex and a simple loop.
>       Since some blas norm suck I off-hand told Shri to use dot for
>     norm and wasn't thinking the complex case.
>       Since then, of course, the complex dot problem has been coming up.
>       Maybe it is best to continue to never use complex blas dot and
>     just change the VecNorm_ routines to use norm for complex and not
>     dot.? Just throw away this silly problem and time sink?
> Why is this such a problem? Just use PetscScalar for the BLASdot_()
> return type and its fine.
For instance MKL's BLAS returns result for zdot in the first argument
and PETSc's BLASdot_() fails there.
>    Matt
>        Barry
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120227/70023764/attachment.html>
