[petsc-dev] Problem with MUMPS+metis
Sean Farley sean at mcs.anl.gov
Sat Feb 25 23:27:28 CST 2012
> It seems to be a problem with metis' interpretation of the vertex
> weights.  If you set the vwgt=0x0 in a debugger when stopped at
> metis_nodend_ it completes successfully.  Also, if you set the weights to 1
> inside dmumps_part2.F like:
>          DO I=1,NCMP
>            FILS(I) = 1
>          ENDDO
> it also runs fine.  I think having zero vertex weights is probably wrong
> anyways.
Thanks for the bug report. This accidentally happened due to my changes to
patch MUMPS. This should work in petsc-dev now.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120225/17a3a4dd/attachment.html>
