[petsc-dev] Understanding Some Parallel Results with PETSc
Thu Feb 23 23:41:33 CST 2012
Okay, thanks. What is the exact command line you used to set the affinity
correctly? (I want to know the semantics of what you did.)
On Thu, Feb 23, 2012 at 23:37, Dave Nystrom <dnystrom1 at comcast.net> wrote:
> Jed Brown writes:
>  > On Thu, Feb 23, 2012 at 18:53, Nystrom, William D <wdn at lanl.gov> wrote:
>  > > Rerunning the CPU case with numactl results in a 25x speedup and
>  > > log_summary
>  > > results that look reasonable to me now.
>  > What command are you using for this?  We usually use the affinity
> options to
>  > mpiexec instead of using numactl/taskset manually.
> I was using openmpi-1.5.4 as installed by the system admins on our testbed
> cluster.  I talked to a couple of our openmpi developers and they indicated
> that the affinity stuff was broken in that version but should be fixed when
> 1.5.5 and 1.6 come out - which should be within the next month.
> I also tried mvapich2-1.7 built with slurm and tried using the affinity
> stuff
> with srun.  That also did not seem to work.  But I should probably revisit
> that and try to make sure that I really understand how to use srun.
> I was pretty surprised that getting the numa stuff right made such a huge
> difference.  I'm also wondering if getting the affinity right will make
> much
> of a difference for the gpu case.
>  > Did you also set a specific memory policy?
> I'm not sure what you mean by the above question but I'm kind of new to all
> this numa stuff.
>  > Which Linux kernel is this?
> The OS was the latest beta of TOSS2.  If I remember, I can check next time
> I
> am in my office.  It is probably RHEL6.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120223/62284171/attachment.html>
