[petsc-dev] BuildSystem clean-up
Sean Farley sean at mcs.anl.gov
Thu Feb 23 16:33:13 CST 2012
So, apparently, BuildSystem creates a working directory for external
packages specified with the --download-package option. This seems like a
perfect place to do scratch work for the external package but this folder
is not cleaned out when the configure options change. Example:
$ export PETSC_ARCH=arch-test
$ ./configure --download-metis
$ ls externalpackages/metis-5.0.2/arch-test/
FILE1 FILE2 FILE3
Now, I would expect BuildSystem to clean this directory, at the very least,
when options change:
$ ./configure --download-metis --with-precision=single
FILE1 FILE2 FILE3
The same files exist which could spell trouble in this case. Does every
package *have* to implement its own clean-up (this sounds crazy!!) or can I
safely put this into BuildSystem without the Tower of Babel crumbling
around my feet? If this change is "good" then how does BuildSystem
determine that the options changed (self.installNeeded?)? Or should it just
blow away this directory every time?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120223/b16e0a7d/attachment.html>
