[petsc-dev] maxIndSetAgg in gamg
Wed Feb 22 15:46:49 CST 2012
On Wed, Feb 22, 2012 at 11:55, Verena Kuhlemann <vkuhlem at gmail.com> wrote:
> Hi,
> I was planning to use the maxIndSetAgg function in gamg.c but it is not
> available in the newest
> nightly build. Was it thrown out or renamed? Any change it could be made
> available again?
This code is in flux and that function was never public. petsc-dev has a
MatCoarsen object now, of which one implementation is MIS-based
aggregation. The new design should be much better, but it will likely still
evolve some from its current form.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120222/aafbd299/attachment.html>
