[petsc-dev] Crash in MatDestroy_MUMPS
John Fettig john.fettig at gmail.com
Wed Feb 22 11:43:01 CST 2012
On Tue, Feb 21, 2012 at 4:55 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Feb 21, 2012 at 15:38, John Fettig <john.fettig at gmail.com> wrote:
>> Is this likely memory corruption on my side or on the PETSc side, or
>> something else entirely?  I seem unable to reproduce it with an example,
>> unfortunately.  Running it through valgrind may take a week.
> I don't see a reason why that specific line would naturally end up with an
> invalid value, so I suspect memory corruption. Make a smaller problem so
> that valgrind runs fast.
You were right.  I was able to run it through valgrind overnight and it was
definitely memory corruption on my end.  After cleaning that up, the
segfault in KSPDestroy goes away.
John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120222/08722c84/attachment.html>
