[petsc-dev] tests/benchmarks
Gerard Gorman g.gorman at imperial.ac.uk
Tue Feb 21 10:31:22 CST 2012
Gerard Gorman emailed the following on 21/02/12 16:22:
> Hi
> I would like to harvest a selection of typical use cases for
> benchmarking PETSc/OpenMP. Ideally they would have features such as
> preallocating matrices rather than adding one at a time, be easy to
> configure for different problem sizes etc. Has anyone already put
> together such a list - what would be considered good/best practice here?
> Cheers
> Gerard
Further to this - do I recall someone saying they had unpushed bug fixes
to the test cases? For example, I've tried:
ggorman at cynic:~/projects/petsc/petsc-dev/src/ksp/ksp/examples/tests$
./ex10 -m 4
m = 2, N=375
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range!
[0]PETSC ERROR: New nonzero at (6,119) caused a malloc!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
c7afeaa80089c71502abd0b0aca07e7ea2f3d431  HG Date: Tue Feb 21 09:48:53
2012 -0600
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./ex10 on a arch-linu named cynic by ggorman Tue Feb 21
16:28:33 2012
[0]PETSC ERROR: Libraries linked from
/home/ggorman/projects/petsc/petsc-dev/arch-linux2-c-debug/lib
[0]PETSC ERROR: Configure run at Tue Feb 21 16:23:30 2012
[0]PETSC ERROR: Configure options
[0]PETSC ERROR:
[0]PETSC ERROR: MatSetValues_SeqAIJ() line 331 in
/home/ggorman/projects/petsc/petsc-dev/src/mat/impls/aij/seq/aij.c
[0]PETSC ERROR: MatSetValues() line 1142 in
/home/ggorman/projects/petsc/petsc-dev/src/mat/interface/matrix.c
[0]PETSC ERROR: AddElement() line 198 in src/ksp/ksp/examples/tests/ex10.c
[0]PETSC ERROR: GetElasticityMatrix() line 130 in
[0]PETSC ERROR: main() line 41 in src/ksp/ksp/examples/tests/ex10.c
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 63.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
Pretty much the only value for the problem size (ie the -m option) is
the default.
Cheers
Gerard
