[petsc-dev] Mac OSX complex BLAS problem
Sat Feb 18 17:47:28 CST 2012
On Sat, Feb 18, 2012 at 5:34 PM, Jack Poulson <jack.poulson at gmail.com>wrote:
> I think I mentioned this to several PETSc folks two years ago. It is a bad
> idea to return complex numbers from Fortran, as there is no portable
> solution as far as I know; some compilers need you to declare it as
> complex zdotc_( <regular args> )
> some as
> void zdotc_( <regular args>, complex* z )
> and I think I ran into problems with both on OSX (but don't quote me on
> it). I ended up settling on writing my own complex dotc and dotu routines.
That is exactly it. Scipy has a patch for it
http://projects.scipy.org/scipy/attachment/ticket/1321/scipy-r6856-isolve-veclib.patch
So what are we going to do in PETSc folks? It sounds like we need a
configure test for complex dot, and then
and then an #define wrapper for ones that return rather than taking an
argument.
    MAtt
> Jack
> On Sat, Feb 18, 2012 at 5:28 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> We have a problem with complex dot product on OSX. Here is the easiest
>> way to see it (I think):
>> knepley:/PETSc3/petsc/petsc-dev$
>> ./arch-complex-fftw-debug/lib/ex5-obj/ex5 -snes_monitor
>>   0 SNES Function norm 0.000000000000e+00
>> With the debugger:
>> Breakpoint 1, VecNorm_Seq (xin=0x1022fc170, type=NORM_2,
>> z=0x7fff5fbfea10) at bvec2.c:238
>> 238         ierr = VecGetArrayRead(xin,&xx);CHKERRQ(ierr);
>> (gdb) n
>> Current language:  auto; currently c++
>> 239         *z = BLASdot_(&bn,xx,&one,xx,&one);
>> (gdb) p bn
>> $1 = 16
>> (gdb) p xx[0]@16
>> $2 = {{
>>     _M_value = 0 + 0 * I
>>    _M_value = -0.10378182131158753 + 0 * I
>> (gdb) p one
>> $3 = 1
>> (gdb) n
>> 240         *z = PetscSqrtReal(*z);
>> (gdb) p *z
>> $4 = 0
>> (gdb) p zdotc
>> $5 = {<text variable, no debug info>} 0x7fff863e71e2 <zdotc_>
>> It appears that the dot product is producing nothing. Didn't we have a
>> similar problem a little while ago?
>>    Matt
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120218/0d9e9b01/attachment.html>
