[petsc-dev] Merge sets
Sat Feb 18 16:23:04 CST 2012
On Sat, 18 Feb 2012, Jed Brown wrote:
> On Sat, Feb 18, 2012 at 16:18, Matthew Knepley <knepley at gmail.com> wrote:
> > I have lost the BB battle, however can we at least start using
> >   hg pull --rebase
> > so that we avoid this
> >   https://bitbucket.org/petsc/petsc-dev/changeset/ad9064ecab66
> This is a visualization issue.
Yes - I just use 'hg view' - and if its a merge commit - I go to the
parent to check.
But i do use 'hg pull --rebase' for of my [trivial] commits though..
Satish
> $ hg diff -r 63b68cc62c3d..ad9064ecab66
> diff --git a/src/ksp/pc/impls/mg/mg.c b/src/ksp/pc/impls/mg/mg.c
> --- a/src/ksp/pc/impls/mg/mg.c
> +++ b/src/ksp/pc/impls/mg/mg.c
> @@ -1026,17 +1026,22 @@
>  .  -pc_mg_type <additive,multiplicative,full,cascade> - multiplicative is
> the default
>  .  -pc_mg_log - log information about time spent on each level of the
> solver
>  .  -pc_mg_monitor - print information on the multigrid convergence
> -.  -pc_mg_galerkin - use Galerkin process to compute coarser operators
> --  -pc_mg_dump_matlab - dumps the matrices for each level and the
> restriction/interpolation matrices
> +.  -pc_mg_galerkin - use Galerkin process to compute coarser operators,
> i.e. Acoarse = R A R'
> +.  -pc_mg_multiplicative_cycles - number of cycles to use as the
> preconditioner (defaults to 1)
> +.  -pc_mg_dump_matlab - dumps the matrices for each level and the
>                          to the Socket viewer for reading from MATLAB.
> +-  -pc_mg_dump_binary - dumps the matrices for each level and the
> +                        to the binary output file called binaryoutput
>     Notes: By default this uses GMRES on the fine grid smoother so this
> should be used with KSPFGMRES or the smoother changed to not use GMRES
> +       When run with a single level the smoother options are used on that
> level NOT the coarse grid solver options
>     Level: intermediate
>     Concepts: multigrid/multilevel
> -.seealso:  PCCreate(), PCSetType(), PCType (for list of available types),
> PC, PCMGType, PCEXOTIC
> +.seealso:  PCCreate(), PCSetType(), PCType (for list of available types),
> PC, PCMGType, PCEXOTIC, PCGAMG, PCML, PCHYPRE
>             PCMGSetLevels(), PCMGGetLevels(), PCMGSetType(),
> PCMGSetCycleType(), PCMGSetNumberSmoothDown(),
>             PCMGSetNumberSmoothUp(), PCMGGetCoarseSolve(),
> PCMGSetResidual(), PCMGSetInterpolation(),
>             PCMGSetRestriction(), PCMGGetSmoother(), PCMGGetSmootherUp(),
> PCMGGetSmootherDown(),
