[petsc-dev] DMGetMatrix --> DMGetMatrices?
Dmitry Karpeev karpeev at mcs.anl.gov
Fri Feb 10 19:33:41 CST 2012
On Fri, Feb 10, 2012 at 7:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 10, 2012, at 7:04 PM, Dmitry Karpeev wrote:
> > On Fri, Feb 10, 2012 at 7:02 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Feb 10, 2012, at 6:45 PM, Dmitry Karpeev wrote:
> > > On Fri, Feb 10, 2012 at 5:24 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > On Feb 10, 2012, at 5:14 PM, Jed Brown wrote:
> > > > On Fri, Feb 10, 2012 at 17:08, Dmitry Karpeev <karpeev at mcs.anl.gov>
> wrote:
> > > > I think it's completely natural for a DM to assemble two operators
> -- the discretizations for the two are likely to be related anyway -- as
> soon as we decide that it's natural for KSP to take in two matrices and,
> more importantly, for the callback set with DMSetJacobian() to compute two
> matrices: if a DM knows how to compute  two "Jacobians",
> > >    DM doesn't/shouldn't know how to compute two Jacobians. Where did
> you get that from?
> > >  Here's the current declaration of DMSetJacobian:
> > >  PetscErrorCode  DMSetJacobian(DM dm,PetscErrorCode
> (*f)(DM,Vec,Mat,Mat,MatStructure*))
> > > This attaches (to a single DM) a callback that computes *two*
> matrices, just like SNES/KSP would want.
> >   You are right this is odd now and eventually needs some kind of
> fixing. I kept the two Mats to match the SNESSetJacobian(). Of course we
> cannot really use it since a DM can only give back one matrix. Shouldn't
> this be changed to the function f taking two DMs?
> > I think SNES should make two callbacks -- one for each DM -- to have the
> "user" (or an FEM library) compute J and J_pre.
>    That is what I was thinking originally. But Jed pointed out that
> sometimes the work between computing the two Jacobians may be mostly common
> so there should be some way to allow the user to provide code that does
> both together and not have the two callbacks as you list above.
>    We'll never have a perfect design.
How can there be a single callback, when the two DMs could be of different
types?
I guess it could be done using the double-dispatch mechanism:
DMComputeOperators(DM dmJ, DM dmP, Mat *J, Mat *P) would dispatch based on
the types of the two DMs,
and, if no such method exists, defaulting internally to calling
DMComputeMatrix(DM dm, Mat *A) for both J and P.
I still think that DMComputeMatrix() should be different from
DMCreateMatrix() -- the latter just preallocates --
eliminating the need for DMSetPreallocateOnly().
If the two DMs are of the same type and, say, share a mesh, then the dual
dispatch can take advantage of
a corresponding implementation.
Dmitry.
>   Barry
> > Dmitry.
> >   Barry
> > > Dmitry.
> > > > why wouldn't it know how to create/preallocate the two corresponding
> matrices?
> > >   The reason I don't like having the single DM doing this is that one
> could use very different beasties to do the true Jacobian and
> preconditioner (not just a simple stencil change) and shoving that stuff
> into a single DM is unnatural. For example true problem is on an
> unstructured grid, preconditioner problem on a simplier structured grid.
> > > > Lots of functions get messy if the DM has multiple ways to do
> something. Should DMCreateLocalVector() use the full stencil or the
> preconditioning stencil, what should DMGlobalToLocalBegin() be updating,
> etc.
> > > > Barry's solution of having separate DMs sounds cleaner to me, at
> least modulo needing conventions about which DM on which to
> PetscObjectCompose() things needed by certain callbacks (e.g. in the FAS
> with TS stuff I'm doing).
> > >   Clean that up and provide a formal way to do those callbacks that
> don't use kludgy PetscObjectCompose() or PetscObjectComposeFunction()
> > >   Barry
> > > Yes, it will be slightly painful to pass two DM into the KSP and PC
> and track them in multigrid but we do do that with the two operators
> already so using two DM seems very natural.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120210/fa6990c2/attachment.html>
