[petsc-dev] DMGetMatrix --> DMGetMatrices?
Dmitry Karpeev karpeev at mcs.anl.gov
Fri Feb 10 15:08:51 CST 2012
On Fri, Feb 10, 2012 at 12:13 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Fri, Feb 10, 2012 at 00:05, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
>> I don't think so.  Preallocating doesn't set any values and seems to
>> leave the matrix marked !assembled.
>> MatDuplicate for such a matrix will fail.  Assemblying it before setting
>> values (just to force an assembled flag)
>> will squeeze out the extra values, won't it?  I think it would just be
>> reasonable to allow to duplicate unassembled
>> matrices, or, better yet, have a matrix be "assembled" by default until
>> MatSetValues has been called.
>> But I'm not sure whether either solution will break something else.
> Are you calling DMSetMatrixPreallocateOnly()?
> What I'm talking about is an implementation issue, rather than a question
of what the user should expect from the DMGetMatrix API: I have a matrix
that has been preallocated by libMesh based on its mesh connectivity, but
it
has not been assembled. If I didn't want to return it in DMGetMatrix, but
rather to duplicate it, Id be out of luck:
that matrix is not "assembled", hence, cannot be duplicated.  This, in
fact, has little to do with the DM interface.
The question is: should we be able to duplicate such "unassambled"
matrices? Or should they even be call "unassembled"?
Dmitry.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120210/9f13be20/attachment.html>
