[petsc-dev] Someone still cannot use the "annotate" link
Thu Feb 9 18:54:03 CST 2012
  The logic uses the MOAB of the MOAB.py filename to build the name of the tar file it gets. BUT the tarfile has moab in the name NOT MOAB. So it could not have worked with the current logic.  If Dmitry didn't change that file than someone changed the logic and broke it.
  Don't worry it works now.
  Barry
On Feb 9, 2012, at 6:27 PM, Dmitry Karpeev wrote:
> Why not?  It used to work, but I (or anybody, as far as I know) haven't used MOAB.py since last summer.
> On Thu, Feb 9, 2012 at 6:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 9, 2012, at 6:06 PM, Matthew Knepley wrote:
> > Clearly, karpeev was the only use who altered those lines:
> > http://petsc.cs.iit.edu/petsc/BuildSystem/rev/42cbb1d6192f
> > http://petsc.cs.iit.edu/petsc/BuildSystem/annotate/d295489bd56e/config/packages/MOAB.py
> >   Matt
>   Well he never tested them. Cause they didn't work.
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
