[petsc-dev] petsc-dev on bitbucket
Sean Farley sean at mcs.anl.gov
Wed Feb 8 11:36:10 CST 2012
> Generally you want fewer people with root access the closer you get to the
> root directory since the more harm they can do. So for example
> petsc/releases would only have Satish and one other with admin.
Which is perfectly fine and easy to set up now. Hell, if you *really* want
to, just create the account: petsc-release(s) then the URL would be
http://bitbucket.org/petsc-release/petsc-3.1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120208/7e86f133/attachment.html>
