[petsc-dev] petsc-dev on bitbucket
Sean Farley sean at mcs.anl.gov
Wed Feb 8 11:34:31 CST 2012
> Yes. If you can't have that then it is a pretty crappy system. Sort of
> like IBM 360 where you only had a root directory with a truckload of files
> in it. In excusable in 2012 (or even 1972).
You're absolutely right. I mean, what's the point of even having files with
code in them? I want to just draw my matrix block pattern in MS Paint and
have this automatically be run in parallel.
-or-
Why can't I just clone petsc-dev/src/ts??? I don't want the whole goddamn
source tree!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120208/78567e4b/attachment.html>
