[petsc-dev] MatMatMult gives different results
Alexander Grayver agrayver at gfz-potsdam.de
Wed Feb 8 10:53:20 CST 2012
Hong,
Thank you.
In addition, I changed my code and form A^T explicitly (to avoid
previous error) and I got another one:
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Object is in wrong state!
[1]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
argument 1 "mat" before MatAssemblyBegin()!
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Development HG revision:
249597282bcb6a1051042a9fdfa5705679ed4f18  HG Date: Tue Feb 07 09:44:23
2012 -0600
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR:
[1]PETSC ERROR: solveTest on a openmpi-i named glic1 by agrayver Wed
Feb  8 13:06:45 2012
[1]PETSC ERROR: Libraries linked from
/home/lib/petsc-dev/openmpi-intel-complex-debug-f-mkl/lib
[1]PETSC ERROR: Configure run at Tue Feb  7 18:19:58 2012
[1]PETSC ERROR: Configure options
--with-petsc-arch=openmpi-intel-complex-debug-f-mkl
--with-fortran-interfaces=1 --download-superlu --download-superlu_dist
--download-mumps --download-parmetis --download-ptscotch
--download-metis
--with-scalapack-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_scalapack_lp64.a
--with-scalapack-include=/opt/intel/Compiler/11.1/072/mkl/include
--with-blacs-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_blacs_openmpi_lp64.a
--with-blacs-include=/opt/intel/Compiler/11.1/072/mkl/include
--with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex
--with-blas-lapack-lib="[/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_intel_lp64.a,/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_intel_thread.a,/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_core.a,/opt/intel/Compiler/11.1/072/lib/intel64/libiomp5.a]"
--with-precision=double --with-x=0
[1]PETSC ERROR:
[1]PETSC ERROR: MatAssemblyBegin() line 4795 in
/home/lib/petsc-dev/src/mat/interface/matrix.c
[1]PETSC ERROR: MatMatMultSymbolic_MPIAIJ_MPIDense() line 638 in
/home/lib/petsc-dev/src/mat/impls/aij/mpi/mpimatmatmult.c
[1]PETSC ERROR: MatMatMult_MPIAIJ_MPIDense() line 594 in
[1]PETSC ERROR: MatMatMult() line 8618 in
On 08.02.2012 17:45, Hong Zhang wrote:
> Alexander :
> I can repeat the crash, and am working on it.
> I'll let you know after the bug is fixed.
> Thanks for your patience,
> Hong
>     It seems now I know why I used MAT_REUSE_MATRIX and preallocated
>     matrix.
>     I removed MatCreateMPIAIJ() and use just MatTranspose with
>     MAT_INITIAL_MATRIX.
>     As a consequence I get hundreds of errors like:
>     [30]PETSC ERROR: MatSetValues_MPIAIJ() line 538 in
>     /home/mt/agrayver/lib/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c
>     [30]PETSC ERROR: MatAssemblyEnd_MPIAIJ() line 653 in
>     [30]PETSC ERROR: MatAssemblyEnd() line 4978 in
>     /home/mt/agrayver/lib/petsc-dev/src/mat/interface/matrix.c
>     [30]PETSC ERROR: MatTranspose_MPIAIJ() line 2061 in
>     [30]PETSC ERROR: MatTranspose() line 4397 in
>     [31]PETSC ERROR: --------------------- Error Message
>     [31]PETSC ERROR: Argument out of range!
>     [31]PETSC ERROR: New nonzero at (1659,53337) caused a malloc!
>     Ans this is the lastest petsc-dev revision.
>     I know there were some changes in petsc-dev concerning this issue.
>     Can you give me a hint how to avoid this?
>     As for why I need C=A^T*B. This product is used further as a
>     system matrix for LSQR solver. The largest dimension is on the
>     order of 10^6
>     Since I form A and B myself I can, of course, form A^T explicitly,
>     but I thought I would first implement everything as it is written
>     down on paper and then optimize once it works (I thought it's
>     easier way).
>     On 07.02.2012 20:44, Hong Zhang wrote:
>>     Alexander,
>>     I'm curious about why do you need parallel C=A^T*B?
>>     How large your matrices are?
>>     In petsc-dev, we have MatTransposeMatMult() for mpiaij and
>>     mpiaij, but not mpiaij and mpidense.
>>     We may add support of MatTransposeMatMult_MPIAIJ_MPIDense() if
>>     there is such need.
>>     Hong
>>     On Tue, Feb 7, 2012 at 1:18 PM, agrayver at gfz-potsdam.de
>>     <mailto:agrayver at gfz-potsdam.de> <agrayver at gfz-potsdam.de
>>     <mailto:agrayver at gfz-potsdam.de>> wrote:
>>         Hong,
>>         Thanks for explanation. I will try this tomorrow. Good to
>>         have this stuff in the help now.
>>         And sorry for misleading you initially.
>>         Regards,
>>         Alexander
>>         ----- Reply message -----
>>         From: "Hong Zhang" <hzhang at mcs.anl.gov
>>         <mailto:hzhang at mcs.anl.gov>>
>>         To: "For users of the development version of PETSc"
>>         <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>>
>>         Subject: [petsc-dev] MatMatMult gives different results
>>         Date: Tue, Feb 7, 2012 19:09
>>         Alexander :
>>             There is something I didn't get yet, I hope you could
>>             clarify it.
>>             So, when I use flag MAT_INITIAL_MATRIX in test program it
>>             works fine.
>>         Good to know :-)
>>             If I put this flag in my original program I get dozens of
>>             exceptions like:
>>             [42]PETSC ERROR: Argument out of range!
>>             [42]PETSC ERROR: New nonzero at (1336,153341) caused a
>>             malloc!
>>         You cannot do
>>         MatCreateMPIAIJ()
>>         MatTranspose(A,MAT_INITIAL_MATRIX,&AT);
>>         MatCreateMPIAIJ() creates AT and preallocates approximate
>>         nonzeros, which does not match exactly the nonzeros in
>>         MatTranspose(A,MAT_INITIAL_MATRIX,&AT) creates matrix AT and
>>         sets correct nonzero pattern and values in AT.
>>         MatTranspose() only takes in "MAT_INITIAL_MATRIX" - for a new AT,
>>         and "MAT_REUSE_MATRIX" when AT is created with
>>         and reuse for updating its values (not nonzero patten).
>>         I'm updating petsc help menu on MatTranspose(). Thanks for
>>         the report.
>>         Hong
>>             I changed this flag to MAT_REUSE_MATRIX and exceptions
>>             disappeared, but result is incorrect again (same as for
>>             MAT_IGNORE_MATRIX)
>>             I tried test program with MAT_REUSE_MATRIX and it also
>>             gives different matrix product.
>>             Since there is no description of MatReuse structure for
>>             MatTranspose it's a bit confusing what to expect from it.
>>>>                 Do you mean 'Cm = A'*B;'?
>>>>                 'Cm = A.'*B;' gives component-wise matrix product,
>>>>                 not matrix product.
>>>                 .' operator means non-Hermitian transpose. That is
>>>                 what I get with MatTranspose (in contrast with
>>>                 MatHermitianTranspose)
>>>                 component-wise matrix product would be .*
>>>             You are correct.
>>>             Hong
>>>>                 Hong
>>>>                     C = PetscBinaryRead('C.dat','complex',true);
>>>>                     Matrix C is different depending on number of
>>>>                     cores I use.
>>>>                     My PETSc is:
>>>>                     Using Petsc Development HG revision:
>>>>                     876c894d95f4fa6561d0a91310ca914592527960  HG
>>>>                     Date: Tue Jan 10 19:27:14 2012 +0100
>>>>                     On 06.02.2012 17:13, Hong Zhang wrote:
>>>>>                     MatMatMult() in petsc is not well-tested for
>>>>>                     complex - could be buggy.
>>>>>                     Can you send us the matrices A and B in petsc
>>>>>                     binary format for investigation?
>>>>>                     Hong
>>>>>                     On Mon, Feb 6, 2012 at 5:55 AM, Alexander
>>>>>                     Grayver <agrayver at gfz-potsdam.de
>>>>>                         Dear PETSc team,
>>>>>                         I try to use:
>>>>>                         call
>>>>>                         MatMatMult(A,B,MAT_INITIAL_MATRIX,PETSC_DEFAULT_DOUBLE_PRECISION,C,ierr);CHKERRQ(ierr)
>>>>>                         Where both A and B are rectangular, but A
>>>>>                         is sparse and B is dense. Both are double
>>>>>                         complex and distributed.
>>>>>                         The product PETSc gives me contains some
>>>>>                         errors in some part of the matrix.
>>>>>                         I output A, B and C then computed product
>>>>>                         in matlab.
>>>>>                         Attached you see figure plotted as:
>>>>>                         imagesc(log10(abs(C-Cm)))
>>>>>                         Where Cm -- product computed in matlab.
>>>>>                         The pattern and amplitude vary depending
>>>>>                         on the number of cores I use. This picture
>>>>>                         is obtained for 48 cores (I've tried 12,
>>>>>                         64 cores as well).
>>>>>                         Where should I look for possible explanation?
>>>>>                         Regards,
>>>>>                         Alexander
>>>>                     Regards,
>>>>                     Alexander
>>>                 Regards,
>>>                 Alexander
>>             Regards,
>>             Alexander
>     Regards,
>     Alexander
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120208/134cf8b2/attachment.html>
