[petsc-dev] MatMatMult gives different results
Alexander Grayver agrayver at gfz-potsdam.de
Wed Feb 8 03:01:38 CST 2012
Hong,
It seems now I know why I used MAT_REUSE_MATRIX and preallocated matrix.
I removed MatCreateMPIAIJ() and use just MatTranspose with
MAT_INITIAL_MATRIX.
As a consequence I get hundreds of errors like:
[30]PETSC ERROR: MatSetValues_MPIAIJ() line 538 in
/home/mt/agrayver/lib/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c
[30]PETSC ERROR: MatAssemblyEnd_MPIAIJ() line 653 in
[30]PETSC ERROR: MatAssemblyEnd() line 4978 in
/home/mt/agrayver/lib/petsc-dev/src/mat/interface/matrix.c
[30]PETSC ERROR: MatTranspose_MPIAIJ() line 2061 in
[30]PETSC ERROR: MatTranspose() line 4397 in
[31]PETSC ERROR: --------------------- Error Message
[31]PETSC ERROR: Argument out of range!
[31]PETSC ERROR: New nonzero at (1659,53337) caused a malloc!
Ans this is the lastest petsc-dev revision.
I know there were some changes in petsc-dev concerning this issue.
Can you give me a hint how to avoid this?
As for why I need C=A^T*B. This product is used further as a system
matrix for LSQR solver. The largest dimension is on the order of 10^6
Since I form A and B myself I can, of course, form A^T explicitly, but I
thought I would first implement everything as it is written down on
paper and then optimize once it works (I thought it's easier way).
On 07.02.2012 20:44, Hong Zhang wrote:
> Alexander,
> I'm curious about why do you need parallel C=A^T*B?
> How large your matrices are?
> In petsc-dev, we have MatTransposeMatMult() for mpiaij and mpiaij, but
> not mpiaij and mpidense.
> We may add support of MatTransposeMatMult_MPIAIJ_MPIDense() if there
> is such need.
> Hong
> On Tue, Feb 7, 2012 at 1:18 PM, agrayver at gfz-potsdam.de
> <mailto:agrayver at gfz-potsdam.de> <agrayver at gfz-potsdam.de
> <mailto:agrayver at gfz-potsdam.de>> wrote:
>     Hong,
>     Thanks for explanation. I will try this tomorrow. Good to have
>     this stuff in the help now.
>     And sorry for misleading you initially.
>     Regards,
>     Alexander
>     ----- Reply message -----
>     From: "Hong Zhang" <hzhang at mcs.anl.gov <mailto:hzhang at mcs.anl.gov>>
>     To: "For users of the development version of PETSc"
>     <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>>
>     Subject: [petsc-dev] MatMatMult gives different results
>     Date: Tue, Feb 7, 2012 19:09
>     Alexander :
>         There is something I didn't get yet, I hope you could clarify it.
>         So, when I use flag MAT_INITIAL_MATRIX in test program it
>         works fine.
>     Good to know :-)
>         If I put this flag in my original program I get dozens of
>         exceptions like:
>         [42]PETSC ERROR: Argument out of range!
>         [42]PETSC ERROR: New nonzero at (1336,153341) caused a malloc!
>     You cannot do
>     MatCreateMPIAIJ()
>     MatTranspose(A,MAT_INITIAL_MATRIX,&AT);
>     MatCreateMPIAIJ() creates AT and preallocates approximate
>     nonzeros, which does not match exactly the nonzeros in
>     MatTranspose(A,MAT_INITIAL_MATRIX,&AT) creates matrix AT and sets
>     correct nonzero pattern and values in AT.
>     MatTranspose() only takes in "MAT_INITIAL_MATRIX" - for a new AT,
>     and "MAT_REUSE_MATRIX" when AT is created with
>     and reuse for updating its values (not nonzero patten).
>     I'm updating petsc help menu on MatTranspose(). Thanks for the report.
>     Hong
>         I changed this flag to MAT_REUSE_MATRIX and exceptions
>         disappeared, but result is incorrect again (same as for
>         MAT_IGNORE_MATRIX)
>         I tried test program with MAT_REUSE_MATRIX and it also gives
>         different matrix product.
>         Since there is no description of MatReuse structure for
>         MatTranspose it's a bit confusing what to expect from it.
>>>             Do you mean 'Cm = A'*B;'?
>>>             'Cm = A.'*B;' gives component-wise matrix product, not
>>>             matrix product.
>>             .' operator means non-Hermitian transpose. That is what I
>>             get with MatTranspose (in contrast with
>>             MatHermitianTranspose)
>>             component-wise matrix product would be .*
>>         You are correct.
>>         Hong
>>>             Hong
>>>                 C = PetscBinaryRead('C.dat','complex',true);
>>>                 Matrix C is different depending on number of cores I
>>>                 use.
>>>                 My PETSc is:
>>>                 Using Petsc Development HG revision:
>>>                 876c894d95f4fa6561d0a91310ca914592527960  HG Date:
>>>                 Tue Jan 10 19:27:14 2012 +0100
>>>                 On 06.02.2012 17:13, Hong Zhang wrote:
>>>>                 MatMatMult() in petsc is not well-tested for
>>>>                 complex - could be buggy.
>>>>                 Can you send us the matrices A and B in petsc
>>>>                 binary format for investigation?
>>>>                 Hong
>>>>                 On Mon, Feb 6, 2012 at 5:55 AM, Alexander Grayver
>>>>                     Dear PETSc team,
>>>>                     I try to use:
>>>>                     call
>>>>                     MatMatMult(A,B,MAT_INITIAL_MATRIX,PETSC_DEFAULT_DOUBLE_PRECISION,C,ierr);CHKERRQ(ierr)
>>>>                     Where both A and B are rectangular, but A is
>>>>                     sparse and B is dense. Both are double complex
>>>>                     and distributed.
>>>>                     The product PETSc gives me contains some errors
>>>>                     in some part of the matrix.
>>>>                     I output A, B and C then computed product in
>>>>                     matlab.
>>>>                     Attached you see figure plotted as:
>>>>                     imagesc(log10(abs(C-Cm)))
>>>>                     Where Cm -- product computed in matlab.
>>>>                     The pattern and amplitude vary depending on the
>>>>                     number of cores I use. This picture is obtained
>>>>                     for 48 cores (I've tried 12, 64 cores as well).
>>>>                     Where should I look for possible explanation?
>>>>                     Regards,
>>>>                     Alexander
>>>                 Regards,
>>>                 Alexander
>>             Regards,
>>             Alexander
>         Regards,
>         Alexander
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120208/be105e32/attachment.html>
