[petsc-dev] petsc-dev on bitbucket
Tue Feb 7 21:04:27 CST 2012
On Feb 7, 2012, at 8:14 PM, Sean Farley wrote:
> "Yoo, i've switched petsc-dev over to bitbucket since petsc.cs.itt.edu is down pull/push from https://bitbucket.org/petsc/petsc-dev
>     Sean" - Barry impersonating me
   I'm sure Jed (or Matt in his prime) could have run over to IIT and restarted the machine in less time than this :-)
    Thanks
   Barry
> Since petsc.cs is down, I don't have everyone's public SSH key. For now, if you need push access, just sign up for a free bitbucket account (can also use OpenID) and reply to this email with your bitbucket username. Barry, Matt, Jed, and Peter have write access already. Hong (hzhang), Dmitry (karpeev), and Lois (curfman) should have write access as long as the username in the parenthesis is your correct bitbucket name.
> Also, BuildSystem is here:
> https://bitbucket.org/petsc/buildsystem
> where the same people as above have write access.
> P.S. - To change your current default push url in mercurial, just edit $PETSC_DIR/.hg/hgrc
> [paths]
> default = https://bitbucket.org/petsc/petsc-dev
> or if you uploaded your public SSH key to bitbucket already
> [paths]
> default = ssh://hg@bitbucket.org/petsc/petsc-dev
> More info here:
> http://confluence.atlassian.com/display/BITBUCKET/Using+the+SSH+protocol+with+bitbucket
> P.P.S - While we're at it, here is a nice shortcut in mercurial. Place this in your ~/.hgrc
> [extensions]
> schemes =
> [schemes]
> petsc = ssh://hg@bitbucket.org/petsc
> You can now clone like so: `hg clone petsc://petsc-dev` or `hg clone petsc://buildsystem`
